Whining power steering pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by nmlabonte, Oct 9, 2014.
  1. Oct 9, 2014 at 1:28 PM
    nmlabonte
    nmlabonte [OP] New Member
    Olympia
    95 Tacoma 4x4
    Lifted, 31" tires, cold air intake
    Hi I have a 95 Tacoma 4x4 with a 2.7 and I've had it for about 6 months. It has a very loud power steering whine at all times. It has no leaks and was told it was replaced recently. I got annoyed of it so I bought a brand new pump and the new pump is just as loud as the old pump! Any ideas or suggestions of why that might be or some tricks to fixing it? Thanks!
  2. Oct 9, 2014 at 3:53 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if its not the pump then its a restriction in the steering itself might be a time for a rebuild or replacement
    talk to tyler
    he has a lot of good parts for sale very cheap, but not sure if he has the full steering but he did have a used PS pump so he might have the steering
    http://www.tacomaworld.com/forum/1st...ale-trade.html
  3. Oct 10, 2014 at 5:40 PM
    1stevertaco
    1stevertaco Well-Known Member
    atlanta
    2000 taco 4x4
    sway bar end links
    You might want to check the metal screen that is in your powersteering res. I had a similar problem, that eventually lead to the powersteering pump not working at all. My problem was a clogged metal screen in the res. Worth checking out.
  4. Oct 10, 2014 at 6:44 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Worth a try, go get a can of Seafoam and put a shot in it, a couple of ounces, and see what happens. Put the rest in your tank.
  5. Oct 11, 2014 at 11:35 AM
    nmlabonte
    Olympia
    95 Tacoma 4x4
    I completely cleaned out the reservoir with brake clean and then flushed out the power steering system. When I bought the truck it has power steering fluid in it. So when I put the new pump on, I flushed it with ATF. I also noticed that after I put the pump on, it has traces of metal in the fluid now.
  6. Oct 11, 2014 at 5:17 PM
    keakar
    karl
    louisiana
    I think the metal may have damaged the pump, maybe it was just a cheapo replacement that wasnt as well built as OEM and couldn't handle a little metal in the system. metal will make any pump fail but it usually takes a long time before it wears enough to get noisy again.
    you said it was replaced but do you know if it was replaced with a new one, rebuilt one, or a used one from a salvage yard?
    I would take the hose loose from the return line and flush the system out in the same manner as a tranny flush and when you see no more metal then replace the pump and you should be good.
    to save money try that pump I linked you to from tyler, it came from a working truck so you save money and know its a good unit.
  7. Oct 11, 2014 at 5:22 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
