Whining rear end differential cure???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Howie D, Nov 18, 2020.
  1. Nov 18, 2020 at 2:07 PM
    Howie D
    Howie D [OP] New Member
    2017 TRD Off Road
    removed mudflaps and put 3m clear protective film over nose and down sides by curved body lines to protect paint
    So folks just to share my most recent adventure.... I am the new owner of a 2017 TRD Off Road which has presented the delightful 55 MPH off throttle whine from rear end. After doing the dance twice with Toyota serviceI demanded the service mgr ride with me and he miraculously heard the sound.
    They changed the rear leaf spring damper. Fail
    They opened a case with Toyota US and were auth to change rear gear set. FAIL Toyota said this is normal sound from the rear end. They said it was (no kidding) the sound of "healthy gears meshing and the result of proper machining process). Guess that means that every other truck and car I have ever ridden in was built poorly following their logic . I think they should have at least kissed me first.
    So new ring and pinion didn't change it and damper didn't change it.
    Has anyone found an actual fix? I read a few comments on pinion bearing. Would that have been changed when the popped in the new dif? Did that stop it for anyone? How about rear wheel bearings? Driveshaft carrier bearing?
    I really would like to keep the rig, I've got plans for it. Any help would greatly be appreciated.
    Thanks!
  2. Nov 18, 2020 at 2:34 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Rear wheel bearings. I had one go bad. It droned through the cabin starting around 20. By 60, it was all you could hear. It would calm down a bit going faster, but came back at a higher speeds.
    Howie D[OP] likes this.
  3. Nov 18, 2020 at 2:45 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    Howie D[OP] and Larzzzz like this.
