Whining sound at low speeds and while coasting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matt76”0, Jan 26, 2018.
  1. Jan 28, 2018 at 10:01 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I was typing as you posted, i just meant MY U-joints didn't whine......now my truck does in fact have a whine though. I suspect front diff. needle bearing.
    It finally started a beating sound at high speed, should be able to find it easier now by sight if I pull the CV. Hell, could be the CV. I dunno. the pain of an old vehicle I guess. You have to enjoy finding problems, they're never new again.
  2. Jun 3, 2018 at 3:21 PM
    rob808
    rob808 Member
    Rob
    2014 AC 4x4
    3" BILSTEIN
    Any outcome to this issue? My 2014 sounds to be making the same squeal.
  3. Jun 3, 2018 at 5:00 PM
    1997tacomav6
    Denver
    Same boat, I have a very slight vibration in steering wheel and humming noise between 30-40 mph then goes away for the last 50,000 miles, Dealer can’t find out what it is, says it’s not the wheel bearings as there is no play in them and I have no carrier bearing on a reg cab, still stumped
  4. Jun 15, 2018 at 8:27 PM
    rob808
    rob808 Member
    Rob
    2014 AC 4x4
    3" BILSTEIN
  5. Jul 11, 2018 at 1:07 AM
    darrylsawyer1989
    darrylsawyer1989 Member
    Darryl
    Panama City, Florida
    2010 SR5 4x4
    baja rack, tint, lift, 20" rims nito tires, more to come
    I know this is an old thread but I’m having the same issue. What was your fix?
  6. Jul 11, 2018 at 5:06 AM
    1997tacomav6
    Denver
    Still have it, dealer inspected the front bearings and said they were ok, so don’t know.
  7. Jul 11, 2018 at 7:56 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Have you taken off your front driveshaft to see if it might be in there?
  8. Jul 11, 2018 at 12:57 PM
    1997tacomav6
    Denver
    Mmm no, it does it in 2 wheel drive, 4 wheel drive, in gear, out of gear, with Acceleration and while coasting, does it going around the corner, does it going straight, does it All the freaking all the time,
    And now my ignition key buzzes like a little bee at those specific mph from vibration
  9. Jul 11, 2018 at 1:13 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    frt. driveshaft spins all the time no matter what mode too though.
    I took off my frt. and it def. got rid of my high spd. vibe.
    Looking at maybe the needle next. That's all that's left w/o thinking about pinion.
    I did pull my driveshafts one at a time to find the vibe, changed 1 rear u joint (had a bind at full tilt) and vibe was still there so pulled front. Even though everything seemed fine ON the vehicle both joints on frt. D.S. have a bind (again, only at full tilt) in them. New ones coming now.
    The remaining hum at low spd. is all that's left to chase down. My hum is different though that it's ONLY below 20 mph. More of a shrill hum than a vibe.
    I changed my wheel bearings first thinking like most 4WD's, they needed it every 150K or so.
    Wasted money, they were fine.
    EDIT: Guess what I'm trying to stress here is that if you have a vibe, take the d.shafts down and ANY bind whatsoever in them, even out of the range of motion, makes them suspect. I also was pretty good about greasing mine. Not EVERY oil change but I always saw grease come out.....well, that doesn't mean they were getting grease all the way around. There were dry spots. Those needles wore.
    EDIT 2: I think the only way to make sure grease gets around every cup is to periodically take the U-joints aprt and spin the caps 180°
  10. Jul 11, 2018 at 3:56 PM
    1997tacomav6
    Denver
    I just bought rear ujoints a week ago, maybe I will get front ones too,
    I’m still on my original ujoints at 568,000 miles and was going to replace them just because of my miles.
  11. Jul 18, 2018 at 3:26 AM
    peterpadlock
    peterpadlock Active Member
    Virginia Beach
    2002 Tacoma 115k
    3'' OME lift - 881 & Toytech AAL kit 265/75R16 Procomp AT tires Procomp La Paz wheels
    Im having this problem too - i was certain it was the ujoints.
    Ill replace them, but, hoping to hear of another solution - im also thinking rear pinion ...
    let me know guys
    1997tacomav6 likes this.
  12. Aug 14, 2018 at 10:55 PM
    rob808
    rob808 Member
    Rob
    2014 AC 4x4
    3" BILSTEIN
    so finally got the noise fixed. it was my driveline carrier bearing that was worn. also it had damaged the ujoint just aft of the bearing from the bearing being worn down too far. both ujoint and carrier bearing replaced. vibrations and noise gone. dealership fixed it under warrantt.
  13. Oct 30, 2019 at 1:56 PM
    Landon9995
    Landon9995 New Member
    Ray
    2016 Tacoma TRD Off Road
    I drive a 2016 Tacoma TRD Off Road. I have the same squeak, it is heard in the rear of the truck mostly when coasting between 15 and 30 mph. I replicated the noise infront of the service manager but the technitions could not find any issues after looking at the truck for a week and a half. They told me the technitions checked everything on the bottom of the truck. I am going to set up an appointment to show a technition how to replicate the noise so maybe they can find out what's wrong.
