Whining sound coming from engine bay of my 2009 SR5 V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Dec 4, 2022.
  1. Dec 4, 2022 at 4:55 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Tonight, a whining sound started in my engine bay (1GR-FE). It's present at idle in neutral and while underway. It's proportional to RPMs, and definitely sounds like it's a higher frequency than crankshaft RPM.
    It *almost* sounds like the transfer case does when it's in low range. Needless to say, I'm 2WD high.
    I popped the hood. Two days ago I had the truck state inspected and serviced, which included an oil and filter change. It appears that when they changed the filter, some oil got on the alternator. Could this be causing the whining? Now to be fair, I'm not 100% sure that the oil on the alternator is new.
    There are 125,000 miles on the truck.
    Thanks for any replies.
  2. Dec 4, 2022 at 9:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe a pulley is on the way out.
    TnShooter likes this.
  3. Dec 4, 2022 at 9:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You could remove the serpentine belt and start the truck.
    If the noise goes away, it’s a belt driven accessory.
  4. Dec 5, 2022 at 5:58 AM
    Plasmech
    This morning there was no noise. The truck was in the garage last night and was relatively warm.
    Last night when I had the noise, the truck had been cold-soaked for a few hours.
    Would a needle bearing noise be starting-temperature-dependent?
    Thanks.
  5. Dec 5, 2022 at 6:00 AM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    Alternator.
  6. Dec 5, 2022 at 6:01 AM
    Plasmech
    If it is the alternator or an idler pulley, how long until I'm left stranded? How high a priority should this be?
    Thanks again.
  7. Dec 5, 2022 at 6:23 AM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    I'd just spend the $100 on a rebuilt alternator if you're worried about it going out. Getting a tow truck around the holidays sucks.
    TexasWhiteIce likes this.
  8. Dec 5, 2022 at 9:17 AM
    Plasmech
    Hasn't done it today at all, even after being out in the cold.
    Strange.
  9. Dec 5, 2022 at 9:29 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Power steering pump?
  10. Dec 5, 2022 at 9:38 AM
    TnShooter
    Deogee
    STOCK
    There’s no good answer.
    The best answer is, are you a risk taker.
    I’d also recommend not throwing parts at it. Crawl under there take the belt loose.
    You don’t even have to take it all the way off. Spin the idlers and pulleys. You will know when you hear and feel the one that’s bad.
    shakerhood, Dm93 and b_r_o like this.
  11. Dec 5, 2022 at 9:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like the noise is intermittent.. if/when it comes back try taking the belt off like Tn suggested. That will isolate it to something in the belt drive system.
    If you suspect the alternator is whining, try removing the field connector with the engine running and see if the whine stops. That would indicate a failing alternator.
    A mechanics stethoscope is pretty cheap and can help with noises
    wi_taco, Dm93 and TnShooter like this.
  12. Dec 5, 2022 at 9:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    This. I would bet its an idler pulley myself.
    Loosen the belt and give yourself enough room to free wheel each idler. You'll be able to feel and/or hear a bad one. Mine were noisy only under cold start conditions as you mention, once warm warm they quieted down for the most part.
    shakerhood and TnShooter[QUOTED] like this.
  13. Dec 17, 2022 at 1:33 PM
    Plasmech
    The dealer worked on the truck this week (did front brakes and rotors and some other stuff). They also spent two hours trying to reproduce the noise (that's always present). They could not. They said they think all my idlers are OK.
    The noise almost sounds like a small turbine wind-up.
    WTF could it be?
  14. Dec 17, 2022 at 2:01 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Have you tried any of these suggestions yet?
  15. Dec 18, 2022 at 7:10 AM
    Plasmech
    The dealer tech did all that. I spoke to the service writer several times on the phone during the diagnostic work. I trust that they were thorough.
  16. Dec 18, 2022 at 7:13 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Almost 14 year old truck with 125,000 miles. I'd replace the pullys since they're relatively cheap (and the serpentine belt if you haven't already). Why risk it....
    wi_taco and SR-71A like this.
  17. Dec 18, 2022 at 7:16 AM
    Plasmech
    What does a set of pulleys cost?
    Thanks.
  18. Dec 18, 2022 at 7:23 AM
    TexasWhiteIce
    Texas
    Around $50, give or take, for a set. if you want toyota OEM brand about $150 for the set. But honestly for a truck that old, an aftermarket set is fine.
    And they're easy to replace with basic tools. Took me about an hour to do a few years ago.
  19. Dec 18, 2022 at 9:18 AM
    Plasmech
    Thanks for the info.
    How exactly would I remove all tension from the belt to test if the pulleys are bad? Is there a way to do that? How long can I safely run the engine with no water pump and no alternator?
    Thanks.
  20. Dec 19, 2022 at 9:51 AM
    10YSON
    GREG
    TACOMA & 4RUNNER
    https://www.fjcruiserforums.com/threads/idler-pulley-bearing-failure-what-to-do.127154/
    Your thermostat will still work so if you see it getting hot then shut it off. You won't have to run it long to confirm the fix.
