Whining sound from engine compartment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ozzyhockey, Dec 18, 2010.
  1. Dec 18, 2010 at 7:53 PM
    ozzyhockey
    ozzyhockey [OP] Member
    05 Double Cab
    3" lift, billet grille
    There is a constant whining sound coming from the engine department. I have tried to figure out where it's coming from but I can't figure it out. I have even tried using a hose to isolate it, but no luck. It has to be either the alternator or water pump. Any suggestions or ideas?
    Thanks
    -Nick
    Gdubb70 likes this.
  2. Dec 18, 2010 at 8:02 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Check your engine again. I've had this problem before. It's the wife. She whines all the time, I hear her in the truck as well. Most of the time, she hides right under the air box.
    jammer, syswalla, TacomaWilly and 2 others like this.
  3. Dec 18, 2010 at 8:10 PM
    ozzyhockey
    05 Double Cab
    hahaha i'll check it out
  4. Dec 18, 2010 at 8:44 PM
    SadManGrin
    SadManGrin Active Member
  5. Dec 18, 2010 at 8:47 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Did you put a supercharger in your truck???:rolleyes: Hows that going for ya
    nudavinci64 likes this.
  6. Dec 18, 2010 at 8:59 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i like using a pry bar to listen for sounds and try to locate/isolate them. a huge screw driver can work too. just apply the tool to a part of the piece you think is making the noise and cup your hand over your ear next to the handle. it can get very hairy on moving items so be careful. could be a pulley bearing or a belt that is too tight. it also could be more involved like you said.
    Freeheelbillie likes this.
  7. Dec 19, 2010 at 3:31 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I had the same issue and it turned out to be a couple of bad idler pulleys. Pull the belt from the front and start the engine. If it is one of the pulleys the noise will now be gone.
    wi_taco, Leomania and Zarsnchz like this.
  8. Dec 19, 2010 at 8:25 AM
    ozzyhockey
    05 Double Cab
    The thing is that it whines like this while I'm driving too, no matter how fast
  9. Dec 19, 2010 at 9:18 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    does the whine get higher pitched with vehicle speed? does it get higher with engine speed?
  10. Dec 20, 2010 at 11:51 AM
    ozzyhockey
    05 Double Cab
    Yes it does get a little higher pitched with speed. It kind of sounds like a supercharger
  11. Dec 20, 2010 at 11:53 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    when i cracked my rack and pinion it whined like non other
  12. Dec 28, 2010 at 3:03 PM
    hakan
    hakan Active Member
    hakan
    SF
    2002 toyota tacoma 4x4 TRD Off Road 3.4
    trail gear weld on rock sliders, leer camper, OME 883front Dacar springs in back, grey wire mod, rear diff breather mode, maglight mode, deck plate mode, camper shell defrost mode, UWS tool box,( viv air inboard air is coming soon)
    it sounds like a rack and pinion problem, I have the same issue right now. check to see if your steering fluid is where its supposed to be. specially it will make the noise when its being turned while standing. Good luck.
  13. Dec 28, 2010 at 3:57 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Could it be radio noise, from a bad ground maybe?
  14. Mar 20, 2018 at 9:23 AM
    Mark.H154
    Mark.H154 Member
    Mark
    Folsom , CA
    2013 Tacoma 4x4
    None yet
    Did anyone come to a conclusion to what this noise is? I have the same with my truck. It's kinda hard to describe.
    Its a very low pitched whine/hum when the motor is turned on. You can hear it when idling, accelerating and decelerating. The more throttle applied the higher pitched and loud it gets. Not sure if it is a true problem or a sign of an underlying problem. But it sounds like a valve that open's when you apply throttle and lets either air or fuel in.
  15. Nov 16, 2019 at 8:04 AM
    Full_enchilada
    Full_enchilada Well-Known Member
    BC Interior
    2023 SR5 Celestial Silver DCLB
    I also have a dumb kinda humming/whining/metallic noise. I have a lil video here if someone wants to assist in detective work.https://youtu.be/v3VxLzFWvJU
  16. Nov 16, 2019 at 8:44 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Hi.
    Start with your idler pulleys.
    You can *carefully* stick a piece of tubing (you have some from the other fluid changes you do, right?;)) on/near the pulley and the other in your ear. You will be able to tell right away.
    Or just skip this entirely and buy a set of idler pulleys (not the tensioner pulley - yet) from gates and replace them 9/10 times that’s what this issue is in 2nd gens.
    The other pulleys tend to be a little more robust.
  17. Nov 16, 2019 at 9:12 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  18. Nov 16, 2019 at 9:17 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I had a whining sound also. 1 week later alternator went bad
  19. Nov 16, 2019 at 1:45 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I often hear a whine from the passenger seat, when my wife is with me
  20. Nov 16, 2019 at 2:38 PM
    TacomaWilly
    TacomaWilly Well-Known Member
    I bet it's your alternator. Mine had to be replaced at 150K miles.It made a very noticeable whine and you could smell it too. If your battery dash light isn't on yet it will be soon.
    Cheers
