whining sound on hard turns
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacozx6r, Aug 7, 2014.
  1. Aug 7, 2014 at 3:56 PM
    tacozx6r
    tacozx6r [OP] Well-Known Member
    Has anyone experienced what is best described as a whining or ringing sound on hard turns? I can't tell where the sound is coming from but it seems to be from the front end. The sound lasts for a couple of seconds then goes away.:confused: Basically if I take a sharp corner and compress the outside of my suspension on either side it gives me a sound that is like a high pitched ringing. The truck has 6200 miles so I'm hoping there aren't any power steering problems cropping up but my fear leads me this direction. No other associated problems. I have a 3 inch bilstein 5100 lift and 295 70 17 trail grapplers iif anyone is curious. Any help or hints would be much appreciated.
  2. Aug 7, 2014 at 3:58 PM
    Large
    Large Red
    Why not take it to the dealer..
  3. Aug 7, 2014 at 4:02 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    x2
  4. Aug 7, 2014 at 4:09 PM
    tacozx6r
    Yeah I just called there to talk to someone and of course the first person I talked to didn't have any idea and everyone else was "busy." Oddly enough I just took it to the dealer for the basic 5000 mile warranty service and not long after is when the sound became prevalent. I heard it once before that but I guess I didn't think much of it until I realized I can actually cause the sound by purposely taking a sharp turn...which I now avoid.
    I'll definitely be following up with the dealer but I would have to assume that I'm not only person to hear this sound before.
  5. Aug 7, 2014 at 4:13 PM
    Jester243
    Dan
    Spokane, WA
    Have you checked your PS fluid level?
  6. Aug 7, 2014 at 4:21 PM
    Ghost.
    Ghost. TW 1%er
    Raymond
    Anchorage, AK
    4runner, Taco, GX460, Tundy
    Just about to say that.
    Powersteering fluid all the way
    take it to a dealer is BAD advice.
    If its something like fluid levels and NOT covered under warranty (which basic maintenance is not) you will pay $80 for toyota to tell you your power steering fluid is low
    EDIT NM just saw the mileage, if you are having PS problems that early there is something wrong
  7. Aug 7, 2014 at 4:33 PM
    tacozx6r
    Yes it's just below max level. Too much perhaps?? I checked while the engine was warm.
  8. Aug 7, 2014 at 4:45 PM
    tacozx6r
    I'm not completely sure there's anything wrong with the PS because I'm not experiencing any symptoms beside the sound. Again its only under hard (ish) turns. Could it be related to the slip detection? I've already experienced a less than pleasant occurrence of the VSC kicking in when not wanted.
  9. Aug 7, 2014 at 4:57 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    It not just something like a tire squealing, is it? I noticed mine started doing that at around 6000 miles. These stock tires are pretty crappy.
  10. Aug 7, 2014 at 5:09 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    My '93 Toyota truck did the same thing at full lock. Smeared some grease on the steering stops every oil change, solved it. Never happens on my new truck.
  11. Aug 7, 2014 at 5:13 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Does it do it stationary with the wheel on hard lock? Is it still making it when you come away slightly from full lock?
  12. Aug 7, 2014 at 5:17 PM
    tacozx6r
    no I dont think its the tires. Almost brand new Nitto TGs.
    Could it be the brakes? Like the vehicle thinks I'm losing control and is doing something to counteract it? Hmm..
  13. Aug 7, 2014 at 5:19 PM
    tacozx6r
    No I've noticed it only happens if I'm going maybe 20 mph or more. The wheel is definitely far from full lock. Just some lean from taking the corner
  14. Aug 7, 2014 at 6:11 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Is the titr rubbing on the fender liner due to body roll? My old civic si did this BC of the drop.
  15. Aug 7, 2014 at 6:13 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Tire rub on front cab mounts, or inner fender? See if there are any clean marks in these locations where the rubbing may happen
  16. Aug 7, 2014 at 7:38 PM
    tacozx6r
    I have had rubbing issues in the past and it doesn't sound like rubbing. Right now I'm not rubbing the cab mount. (Combination of LR UCAs and a great alignment guy). At this point I'll leave well enough alone since it's really nothing more than a strange sound. Again it sounds mechanical... As though the truck is doing something..it sounds exactly the same every time. Same duration, same pitch. Maybe a sensor?
  17. Dec 11, 2014 at 10:59 PM
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    I just found this thread. Mine '13 does makes the same sound when I take a turn to hard or just turn the steering without even going fast a lot. I thought it was the VSC or something, but I think I'm going to take it to the dealership to have it looked at since its still under warranty to be safe.
  18. Dec 12, 2014 at 10:57 AM
    tacozx6r
    I found it was the VSC. Not sure if it has anything to do with my 33" tires. Going to be going with 35s soon so if it gets worse I'll have to find some solution. ..
