Whining sound when hitting gas pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thomas670, Jan 11, 2022.
  1. Jan 11, 2022 at 3:50 AM
    Thomas670
    Thomas670 [OP] Well-Known Member
    2002 Taco Regular 5 speed
    Hey guys was wondering i hear this audible whining sound when i hit the has pedal when im in neutral. Check under the hood everything seems connected and okay. Any thoughts?
  2. Jan 11, 2022 at 6:41 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Loose Alt-PS-AC belts?
    How fast is the engine running when the noise occurs? Need more info to diagnose than you provided :pccoffee:
  3. Jan 11, 2022 at 6:54 AM
    Thomas670
    I know i tried to upload a video but it failed. Basically around normal idle levels 700-900 rpms. It seems to whine when i hit the gas pedal and even whines louder upon acceleration. I think my belts are tight, could it be my alternator showing signs of failing? i might have to re-diagnose because i was doing this fairly quick before i drove to work.
  4. Jan 11, 2022 at 7:00 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Someone install a supercharger while you weren't looking?
    mluckey and Andy01DblCabTacoma like this.
  5. Jan 11, 2022 at 8:25 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    That's what happened to me....
    se7enine[QUOTED] likes this.
  6. Jan 11, 2022 at 2:48 PM
    Thomas670
    So just went under the truck and it seems to be a louder whine when under the front the vehicle under like the a/c compressor. At idle the while is low but pushing on the gas the whine get louder. Is it possible to pull one of the belts to see if the whine is still there to eliminate possibilities?
  7. Jan 11, 2022 at 3:30 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    That's a great idea. You can also spin stuff by hand with the belt off. Something gritty or sloppy will stand out.
    Do you have enough power steering fluid?
  8. Jan 12, 2022 at 6:01 AM
    skeezix
    Colorado
    1998 Limited
    Your AC idler bearing could be going out. Cheap and easy fix, under $10 and 1 hour. Search this forum for "AC Idler Bearing".
  9. Jan 12, 2022 at 6:12 AM
    LiftedOn35s
    LiftedOn35s Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    My truck does this as well but only with the clutch pedal let out so I'm pretty certain mine is (if my memory serves me right) the transmission input shaft bearing, which is known to be noisy. This may be your issue as well. Try idling and revving in neutral with the clutch pushed in and see if it still does it.
    Currygoat likes this.
  10. Jan 13, 2022 at 8:05 AM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Mine started too about 9 months ago (only when the clutch is out, in neutral or in gear). From my understanding its the input shaft bearing slowly wearing. Stops in 4th gear when its direct drive. Lots of folks have reported this, some replacing the bearing when they get their clutch done, only to have it come back 10K miles later. I know @eon_blue had this issue too.
    LiftedOn35s likes this.
  11. Jan 13, 2022 at 7:55 PM
    LiftedOn35s
    Noah
    Northeast FL
    I meant to say this as well. I've just learned to live with it because even if it gets replaced it'll probably just end up back.
    I also did a lot of looking into it at first and it doesn't seem to mean that it's in bad condition either, it's just how it is.
