whining/ticking sound when accelerating
Discussion in '1st Gen. Tacomas (1995-2004)' started by ekalblake, Oct 8, 2023.
  1. Oct 8, 2023 at 8:31 AM
    ekalblake
    ekalblake [OP] Member
    hello,
    my 2003 OR manual has a whine/ticking sound when I am accelerating. Tends to go away when I'm not. Kinda sounds like a cricket. I can hear it through the ac vents. Any ideas what this could possibly be? Thanks!
  2. Oct 8, 2023 at 4:01 PM
    tacohounds92
    tacohounds92 Member
    '99 Tacoma extra cab 4x4
    Certain speed/rpm? Is it the engine ticking or is it something flapping around in the vents possibly? My first thought was exhaust leak.
  3. Oct 9, 2023 at 2:45 PM
    ekalblake
    Happens at all speeds, I think. I can't hear it at higher speeds because the sound is quieter than ambient noise of ~ 30 mph+. It only happens when I am engaging the gas pedal. The sound rises up when I accelerate and dissipates when I let off. It's kind of like a whooshing/airy sound with a subtle ticking. Not terribly loud. I think its coming from the steering column or somewhere in the engine bay. I assume its not something with the AC because it feels connected to the gas pedal?
  4. Oct 9, 2023 at 3:50 PM
    tacohounds92
    tacohounds92 Member
    Exhaust leak probably
  5. Oct 9, 2023 at 4:10 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Belt too tight, loose, worn?
  6. Oct 9, 2023 at 8:05 PM
    mike759
    mike759 Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    I also have this and have for a while on my 3.4. I had just assumed it was the fan speeding up as rpm increases but don't take my word because I have absolutely no clue. I'm intrigued if someone knows the root of this issue
  7. Oct 10, 2023 at 7:09 AM
    ekalblake
    i also noticed yesterday that my coolant reservoir was almost empty. could it be a water pump thing?
  8. Oct 10, 2023 at 12:56 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Check for exhaust leak. I’d start at the exhaust manifold/headers. If you can send us a video
  9. Oct 18, 2023 at 2:03 PM
    ekalblake
    what should I be looking for? sorry I am dumb.
  10. Oct 18, 2023 at 2:30 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The injectors are known to be loud on these trucks. If it's not an exhaust leak, likely an injector.
