Whiny manual trans... why??
Discussion in '1st Gen. Tacomas (1995-2004)' started by tawd77, Mar 11, 2010.
  1. Mar 11, 2010 at 2:54 PM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    I have a 01 Tacoma V6/5spd/4wd - The transmission has a whiney sound in first, second and a little bit in 3rd gears. Kinda like the whine when you go in reverse. Anyone else have this problem? Anyone know how much, and what type of fluid goes in this so i can check to see if its low? thank you!
    EDIT. I opened up the FILL plug on the tranny and it was full of clean gear oil. Any ideas why it has a whine?
  2. Mar 12, 2010 at 2:37 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    synchros are going out.
  3. Mar 12, 2010 at 8:50 AM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    Are you serious? People like you shouldnt be allowed to post answers on any forum. Do you even know what a synchro is, or what it does?? My transmission shifts perfectly. Works perfect in every way, besides a little whining in 1st-3rd gears. That has nothing to do with synchros.
    Im not trying to be a dick, but unless you know what your talking about, please dont reply. All you do is cost people unnecessary time/money.
  4. Mar 12, 2010 at 8:56 AM
    pittim
    pittim mittip backwards
    Pink slider.
    Straight cut gears.
    *Edit. Maybe. I know straight cut gears whine, and I'm pretty sure reverse is straight cut.
  5. Mar 12, 2010 at 9:11 AM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    So is this just a normal whine, or do you think maybe there is a defect in my gears? I recently had a 2001 5 speed 4cylinder 4wd taco, and I didnt notice it whining like this one does. But yes, it does sound like reverse, just not as loud.
  6. Mar 12, 2010 at 9:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    How is the oil level?
  7. Mar 12, 2010 at 9:13 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    That's weird, mine doesn't do that. Maybe you just need to change the fluid. I hear Red Line MT-90 is the best. Im not sure on the capacity though.
  8. Mar 12, 2010 at 9:19 AM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    Oil level looked good. I took out the "check" plug bolt, and clean fluid ran out of it. maybe there is a chance they used the wrong viscosity? Maybe I will drain it and try the redline stuff. Can you get that at a parts store like oreilly's or autozone? thanks!
  9. Mar 12, 2010 at 9:21 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I think you have to get it online but im not sure.
  10. Mar 12, 2010 at 9:24 AM
    pittim
    Pink slider.
    If oil was coming out of the fill plug that isn't too good. From what i've read, you're supposed to fill it just before the level reaches the fill plug.
    I've looked for Redline around here and haven't been able to find. Cheapest place I found it after shipping was from here
    It's $9 shipping for the entire order, so if you need to do a fluid swap anytime in the near future, I'd just buy everything at once.
    Trans needs 2.3qt of GL4 or GL5 (many people say use GL4, which is what the MT-90 I linked is)
  11. Mar 12, 2010 at 9:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Overfilling the gear case can cause the oil to "Froth", and it wont lubricate well.
  12. Mar 12, 2010 at 10:14 AM
    xpdishun
    xpdishun Active Member
    10 AC SR5 4x4 6MT V6
    All the forward gears in any manual transmission are helical gears so they maintain constant contact as they interact meaning smooth silent operation.
    Reverse requires the use of an idler gear to move into place and cause the transmission to rotate backwards. The idler gear can only move in place if the gears are straight cut. Straight cut gears mesh very well, especially with current manufacturing but they don't maintain 100% contact during transfer from one tooth to another. This create impacts with every tooth transfer and hence the characteristic whine.
    As your transmission wears, especially in the lower gears that have the most force applied to the teeth, the helical gears can start wearing to the point where their constant contact isn't so constant anymore. It will never whine like reverse but there may be minor transfers, so 99.9% contact.
    If the truck has a lot of miles on it, you accelerate like a jack rabbit, or your transmission is improperly maintained this will happen sooner. Not accusing you of any of these, especially since you might not be the original owner. The only way to stop it is to replace the transmission or wear ear plugs.
    Might not be your problem but from your symptoms, chances are pretty high this is it.
  13. Mar 12, 2010 at 1:33 PM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    sounds like a pretty good explanation to me. i just bought the truck, and it has 109k miles on it. Im unaware of how the previous owners drove it. I will change the fluid, and put in the proper amount, and if that doesnt help, i guess I will have to live with it. Its not THAT bad, but it was enough to notice, and would like to correct if possible. Thank you all for your replies!
  14. Mar 21, 2010 at 9:41 AM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    mine does it too. bought it at 60k. i havent noticed any problems from it and just assumed that was the way it is. i have put about 25k on it since then
  15. Mar 21, 2010 at 9:54 AM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    mmmm.....it's a truck! With a truck tranny.
  16. Mar 21, 2010 at 12:24 PM
    tacovic
    tacovic Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    mine does this too. my previous tacomas did it as well. so its not bad that its does it?
    nagelg.. where are you at in MN
