Whipsaw 2012
Discussion in 'Canada' started by bluesteel731, May 27, 2012.
  1. Aug 14, 2012 at 11:05 PM
    #141
    bluesteel731
    bluesteel731 [OP] Toy taco
    PNW Vancouver BC
    07 White TRD Tacoma DCLB
    FX-R III, Bestop, custom rock sliders, 2.5 ext RR kings 650/14, icon uca w/Delta Joints, AP expo, bilstein 5165 9.5" w/stem to eye, OBA ARB compressor and ARB rear locker, MR304 w/Cooper STT PRO 295/70/17, TAC WORX light bar mount behind the grill, Rock lights, OTRATTW switches, TAC WORX bed rack with hilift mount, TJM RTT w/annex, CMC
    i got through all except for one spot where calgaryrider got damage from. other than that i think good tires and a leveling kit would be the bare minimum to hit up whipsaw, but had it been raining i think my out come might had been different in some spots.
    i did some how managed to get a branch caught in my sliders..... half of which is still there since i haven't crawled under to dislodge it.
  2. Aug 15, 2012 at 7:09 AM
    #142
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Yes, we had a stocker with us. Made it through ok.
    But you do run a lot higher risk of smashing up your shit. The amount of high rocks and funky angles make it very easy to damage under your rig. My Skid Row Plates took a beating. Nice for piece of mind. I have 2inch of lift up front but with plates+ARB bar i don't think its enough. Tonight Im putting on some new OME's :D
  3. Aug 15, 2012 at 7:26 AM
    #143
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    The rocks were fun...I was disappointed with trail difficulty though. Very easy..
  4. Aug 15, 2012 at 9:39 AM
    #144
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    What springs u going with Reese? Iam very happy with my ome 885s. The leaf spring though, Id like something taller.
  5. Aug 15, 2012 at 10:42 AM
    #145
    bluesteel731
    PNW Vancouver BC
    Factory suspension with a leveling kit, I think without the extra height in the front I wouldve smashed up a lot more shietz.
  6. Aug 15, 2012 at 10:54 PM
    #146
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
    Here's some of the pics...
  7. Aug 15, 2012 at 10:57 PM
    #147
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
  8. Aug 15, 2012 at 11:00 PM
    #148
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
  9. Aug 15, 2012 at 11:04 PM
    #149
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
    **Sorry, didnt get much pics of the other trucks, my truck was always in the back! Only got 4 vids too..
  10. Aug 16, 2012 at 8:36 AM
    #150
    Spoonman
    Jamie
    Alberta
    Sweet pics...I've been there!?!
  11. Aug 16, 2012 at 12:26 PM
    #151
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Wow amazing pics. Really makes me want to buy an actual camera with a proper lens instead of the good ol iPhone! Very sharp.
    Once I get all my pics up on photobucket I will just link the album.
    I got the OME 881's. Rated at 2" of lift up front. If I want more I can just set the 5100s up higher. For the time being im setting 5100s at zero so i have full travel in the springs. Any higher and will be too much wheel well for my liking, and no plans on putting on bigger tires.. yet..
    You saw my truck with the 5100s set up top thats how saggy my springs were! Not sure when they were changed last but long over due. I installed one side last night and ran out of time. Other side tonight and should do it twice as quick cos i know what im doing now :D
  12. Aug 16, 2012 at 12:32 PM
    #152
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I would not set the 5100's any higher than 0. That will preload the spring which can/may cause damage. Just a heads up in case you didnt know
  13. Aug 16, 2012 at 1:54 PM
    #153
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Because the 5100's are a longer travel shock, but stock length, adjusting it to 2.5 will cause no problems. They are also valves better and shouldn't bottom easily. Spacer lifts are the issue on stock struts.
  14. Aug 16, 2012 at 1:55 PM
    #154
    1GR
    Scott
    BC, Canada
    Valved*. Damn auto correct on tapatalk.
  15. Aug 16, 2012 at 2:01 PM
    #155
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    It's your phone knot tapatalk
    ------------------ see ^^
  16. Aug 16, 2012 at 2:29 PM
    #156
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I know. But the issue is he would be preloading the coil springs. The coils arent designed to be lifted more than they already are. The OME 881's are already lifting the truck. If you start lifting the coil with the shock it can cause problems and be "unsafe"
  17. Aug 16, 2012 at 2:49 PM
    #157
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
  18. Aug 16, 2012 at 4:55 PM
    #158
    1GR
    Scott
    BC, Canada
    With 881's you could set it to .75 max. No more then that.
  19. Aug 16, 2012 at 4:59 PM
    #159
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Is that for 2nd gens or 1st gens? or both?
  20. Aug 16, 2012 at 5:49 PM
    #160
    1GR
    Scott
    BC, Canada
    1st. I wouldn't put 881's in a 2nd gen. 884-885. 886 with bumper and winch.
