Whirling Noise, Drive Train.
Discussion in '1st Gen. Tacomas (1995-2004)' started by PrezidentRedz, Aug 11, 2009.
  1. Aug 11, 2009 at 7:49 AM
    PrezidentRedz
    PrezidentRedz [OP] Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Uhh Im going to shoot my truck.
    Just got my TW Drive Shaft back, and this whirling noise... Iv heard for a while( was faint) is now very noticeable. should I be concerned. Im out of ideas on what it could be. Iv already had the rear pinion bearing replaced. so IDK anymore.
    Any Ideas.
  2. Aug 11, 2009 at 7:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Carrier bearing?
  3. Aug 11, 2009 at 7:54 AM
    PrezidentRedz
    Redz
    Owings, MD
    Sorry I should have mentioned I have the Tom Woods Double Cardon Single Tube Drive Shaft.
    So no Carrier Bearing.
  4. Aug 11, 2009 at 8:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Well, that makes this simple..............I think.
    You have a progressive "whirling" noise from the rear of the truck. Does it change (get louder) with increased speed?
  5. Aug 11, 2009 at 8:47 AM
    PrezidentRedz
    Redz
    Owings, MD
    Well maybe, Haven t really had it that fast but ya I hear it real well around 50mph.
  6. Aug 11, 2009 at 8:54 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    How does the angle compare to the old drive shaft?
    I take the u's were replaced also? Greased?
  7. Aug 11, 2009 at 8:56 AM
    PrezidentRedz
    Redz
    Owings, MD
    angle isnt bad. If anything My pinion is a tad positive.
    the old 2/pc shaft also made this noise. so its hard to tell where its coming from.
    yeah and everything is greased.
  8. Aug 11, 2009 at 9:00 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Well, if you had the pinion bearing changed and the sound exsisted pre-shaft swap maybe it is in the tranny. Perhaps the output bearing? Or maybe a rear wheel bearing?
  9. Aug 11, 2009 at 9:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Fast "wiring sound" = pinion or tranny output
    Slow "wiring sound" = wheel bearings.
  10. Aug 11, 2009 at 10:04 AM
    PrezidentRedz
    Redz
    Owings, MD
    Thanks Chris and 98. Thats what I was scared of. my trans also makes a slight rattle\rubbing\rolling sound when down gearing slowing down. so thats where I had a feeling it was coming from.
    and maybe because theirs no play in the Shaft now. (ex, single tube) Im noticing the vibrations????
  11. Aug 11, 2009 at 10:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Highly likely. You can always drop the shaft, put the tranny in nuetral and spin the output slowly. If its a gear (or worse-gear) you should be able to feel some resistance and possible grinding. Also, drain your fluid to see if there are any metal fillings.
