Whirring noise 2013 Tacoma
Discussion in 'Technical Chat' started by clh.0126, Jun 12, 2023.
  1. Jun 12, 2023 at 9:17 AM
    clh.0126
    clh.0126 [OP] Member
    Cam
    none
    With just under 70k on my Tacoma I heard a whirring noise on my Tacoma. After 35 years as both Auto body repairman and certified in suspension, air conditioning and many other areas I was confident it was front wheel bearings so I replaced both front wheel bearing hub assemblies. I still had the noise! I took it to a local mechanic where they said the Dorman hubs were defective and I should have them warranted. So I went to same local parts store and got two more and replaced them again per specs. Still have same issue. I am thinking of replacing the left drive shaft assembly and or servicing the transfer case lube, one at a time to get rid of noise. Any suggestions?
  2. Jun 12, 2023 at 10:11 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does the noise change or go away in 4wd?
  3. Jun 12, 2023 at 10:32 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Put your truck in N going down a hill see if you can still here it
  4. Jun 12, 2023 at 10:44 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...Got a video?
  5. Jun 12, 2023 at 12:03 PM
    clh.0126
    Cam
    none
    Noise goes faster as you speed up and slower as you slow down. Yo start hearing it around 35 to 40 mph
  6. Jun 12, 2023 at 2:45 PM
    MR5X5
    MR5X5 Well-Known Member
    ...or you can do the suggested and answer the questions asked. Your choice.
  7. Jun 12, 2023 at 4:08 PM
    clh.0126
    Cam
    none
    I now have replaced the left front axle shaft and the transfer case lube, noise is still there! I'm now certain that it is the bearing where the left axle meets the transfer case. In response to the gent who suggested switching in and out of 4WD I did and it made no difference!
  8. Jun 12, 2023 at 4:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you tried switching to 4wd and seeing if the noise changes or goes away?
    There is a needle bearing in the front diff that is known to make noise, the test for it typically is to see if the noise goes away in 4wd.
  9. Jun 14, 2023 at 2:23 PM
    clh.0126
    Cam
    none
  10. Jun 17, 2023 at 12:58 PM
    clh.0126
    Cam
    none
    Someone said it could be tires. I have heard similar sounds from tires so I rotated lt frt to lt rear and lt rr to lt frt, no diff!
  11. Jul 1, 2023 at 12:19 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    From my experience at that mileage its front wheel bearings, lift the front end and spin the front tires while holding your coil spring. You will feel the "roughness". Front bearings are also easy to hear when driving, sounds like you are driving on super swampers.
  12. Oct 26, 2023 at 8:59 AM
    clh.0126
    Cam
    none
    Well folks, just so you know, a rear bearing noise can resinate forward through the frame and sound "for sure" like a front wheel bearing gone bad. I replaced both front wheel hub assemblies and the left front axle shaft and still had the noise. I then took it in to a reputable mechanic in TC Mich where they diagnosed front wheel bearings failed. I then told them I replaced and they told me they were defective. I then, frustrated took to another recommended shop and had them replace the rear wheel bearings. Problem solved! I would have done myself but don't have a press and one is required for the rears. Again failed rear wheel bearing noise can sound like its coming from the front!
