Whirring noise, hum, small vibration starting at around 30mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Apr 8, 2011.
  1. Apr 8, 2011 at 8:17 AM
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    Hey, I have a 06 Taco, auto, and I have this strange whirring noise that I hear at aournd 30mph...and the faster I go the faster the whirring noise goes...and the same when I start to slow down. There is a small vibration in the floor as well. I changed the tires as I was told the old ones were cupped and aggressive and that could be my problem but now the noise is lounder with brand new tires (not aggressive at all). I've checked all fluids and I even had the shop check the wheel bearings and he said all was good. (although he just checked for play in the bearings).
    Its driving me nuts, I am going to have to go to the dealer soon...Any help would be appreciated.... Thanks
  2. Apr 8, 2011 at 8:45 AM
    2TRunner
    2TRunner Well-Known Member
    Wheel bearing. Try and listen to the bearing, a long screwdriver would work.
  3. Apr 8, 2011 at 10:05 AM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Is your truck lifted?
    Dont go to the dealer yet.
    It very well could be wheel bearings. My right bearing was going out and started making noise around the same speed you are talking about.
    The wheel showed NO signs of a bad bearing, except for the noise. There was no play in any direction, rolled smooth when turned by hand. When i took it out and got it replaced, looked at the old bearing, it was pitting on the top.
  4. Apr 8, 2011 at 10:08 AM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Wheel Bearing.
  5. Apr 8, 2011 at 11:32 AM
    antatich
    antatich Well-Known Member
    Tony
    Bremen, Indiana
    2011 DC Silver Tacoma
    Ready lift SST w/ 2 inch blocks, 33x12.50R17 Dick Cepek Mud Country Tires, 1.25" Billet Spacers, Tinted Windows, DDM tuning HID Headlights and Foglights, N-Fab Side Bars, N-Fab Light Bar, 4 Hella 500FF, JL Amp, 12" shallow Mount Sub
    ^^ X2 Try removing the wheel and manually turning the hub by hand and see if it feels smooth or somewhat rachety (also put a hand on the bottom of the tire and the other hand on the top and move your arms back and for the check for play). If not smooth or has play then replace it.
