Whirring noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chrism0923, Sep 8, 2020.
  1. Sep 8, 2020 at 8:06 AM
    Chrism0923
    Chrism0923 [OP] Well-Known Member
    2012 silver tacoma
    Been having a whirring/whining noise coming from somewhere going down the road between 55/60mph. I can recreate the sound with the throttle so I suspect ring and pinion or pinion bearing. I hope I’m wrong. Taking it to get checked out today.
  2. Sep 8, 2020 at 9:49 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Does it only do it if your giving it a little bit of throttle? Usually pinion bearings will be heard on acceleration and deceleration.
    Right around 60ish I will get a high pitched whirring noise. But only if I feather the throttle ever so slightly. This is a common issues on the 3rd gen trucks.
  3. Sep 8, 2020 at 11:14 AM
    Chrism0923
    2012 silver tacoma
    It only does it on acceleration and when you first let off the throttle then it’s gone. Mine is a 2nd gen
  4. Sep 8, 2020 at 11:26 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How many miles?
    Is there enough oil in the front diff, transfer case, and rear diff?
    Can you tell where the noise is coming from? Front end, rear end, somewhere else?
  5. Sep 8, 2020 at 11:31 AM
    Chrism0923
    2012 silver tacoma
    220,000. Yes they are all full
  6. Sep 8, 2020 at 12:53 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    If your shop can't pinpoint the source you may want to find one that has something like a Steelman Wireless ChassisEAR. It uses attachable remote microphones to locate noises. Unfortunately they cost around $230 so not something you'd want to pick up yourself as a tool.
  7. Sep 11, 2020 at 11:33 AM
    Chrism0923
    2012 silver tacoma
    They said the noise wasn’t the rear end that it’s an issue that Toyota has. I don’t know that I believe this.
