Whirring sound from engine and dificulty steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by tnewm12, Mar 18, 2015.
  1. Mar 18, 2015 at 7:29 AM
    tnewm12
    tnewm12 [OP] New Member
    97 Toyota Tacoma 3.4L V6
    I have a 97 Toyota Tacoma 3.4L V6. just recently I have been experiencing a whirring noise coming from my engine. At first it only happened when accelerating, but now it does it at idle. The whirring also increases when I turn my wheels while accelerating. This happens the most at cold temperatures and turning is often difficult at first. Power steering fluid level is good. After driving for awhile the noise will often quite down. Any ideas what is causing the problem?
  2. Mar 18, 2015 at 7:31 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Sounds like power steering on its way out.
  3. Mar 18, 2015 at 9:10 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    What you're describing is pretty common when you have a dirty screen at the bottom of your PS res. Drain the fluid, clean and dry your screen and see if that helps.
