Whirring Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Howser, Apr 27, 2010.
  1. Apr 27, 2010 at 7:30 PM
    Howser
    Howser [OP] Active Member
    Midwest
    MGM Dblcb LB Sport 4x4
    I tried searching the forums but didn't find anything definitive on this sound that I am hearing. Its almost like a 1-2 second whirring sound (like something is pressuring up) when I am backing up and shift into DRIVE and wondering if its normal? Typically happens when I shift into DRIVE and go, makes this slight whirring sound very slightly and then stops. Any ideas? Normal?
  2. Apr 27, 2010 at 10:06 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Normal, it's the truck's ABS. If you hit a big enough bump/pothole in the road you'll hear the same noise.
  3. Apr 27, 2010 at 10:17 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yep, should only do it once per trip.
  4. Apr 28, 2010 at 10:04 AM
    Howser
    Midwest
    Thanks for the replies! That makes sense on the noise.
  5. Apr 28, 2010 at 12:43 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    What engine do you have?
  6. Apr 28, 2010 at 12:45 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  7. Apr 28, 2010 at 1:00 PM
    Howser
    Midwest
    I have the 4.0L engine. I wish it was my turbo spooling up unfortunately Toyota didnt include one :).
  8. Apr 28, 2010 at 1:26 PM
    2.7taco
    Texas
    Ok it is as mentioned it is the ABS going through its checks. 100% normal.
  9. Apr 28, 2010 at 2:41 PM
    CopDoctor
    08 335i
    there's a TSB for that ;)
