Whiskey Cabinet BS
Discussion in 'Off-Topic Discussion' started by Kilo Charlie, Feb 11, 2020.
  1. Feb 13, 2020 at 7:29 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I like the "color" from the second or third picture here. I think it is "light yellow" and "orange"?
    I like the angle of this lighting the best out of what you posted.. Is there a dimmer on the LEDs? If so, going this route and dimming a bit might be the ticket, but I don't know what all is getting lost in translation with the photos.
    I don't care for the looks of lights coming up through the bottles, personally. A soft backlight, like what is going on in the speakeasy pic above, is my favorite type of lighting.
    Either way, it's looking really good!
  2. Feb 13, 2020 at 7:39 AM
    USMC - Retired
    USMC - Retired No Better Friend, No Worse Enemy
    Gunns
    Ty Ty, Georgia
    2018 DCSB Quicksand
    My Liquor cabinet door opens downward with supports that make it serve double duty as a "work space" when open. Comes in handy at times. Not the best picture to show it but he only one I have with me.
    trekker and Kilo Charlie[OP] like this.
  3. Feb 13, 2020 at 8:22 AM
    Kilo Charlie
    Kilo Charlie [OP] Disruptor
    Iowa
    2017 Inferno Off Road
    That's pretty bad ass!
  4. Feb 13, 2020 at 8:24 AM
    Kilo Charlie
    Iowa
    I think the bottom picture is the lowest the lights will go. I will have to probably try another brand with more control over the lighting and color.
    bvbull200[QUOTED] likes this.
  5. Feb 14, 2020 at 8:00 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    So here is what I would try. I would take lights not just from the back but also down the sides of the cabinet. This way you get the equal lighting effects. If you're trying to get rid of the light cones you see from the LED's themselves you want want an LED Strip diffuser this will help remove that effect and turn it into more of a solid light bar than points of light. You should be able to find it on like Amazon.
    bvbull200 likes this.
  6. Feb 14, 2020 at 8:02 AM
    Kilo Charlie
    Iowa
    Thanks for your input sir!
  7. Feb 14, 2020 at 8:06 AM
    Kanyon71
    MI
    Most welcome. LED's can be annoying to get the right effects out of but they are also super useful. The strip diffuser is basically a domed looking track you slide the LED strip into, the frosted looking ones (I think they call it milky) seem to diffuse better than the clear ones in my eyes. They can run from cheap like $7-$8 a strip to kits in the $40-$50 range with aluminum trays on the bottom that keep things a little straighter.
    My biggest thing with the LED's and such is take your time and make sure things are in straight lines, with the hard cutoff lines most LED's produce you want to make sure it looks good from the start.
    bvbull200 and Kilo Charlie[OP] like this.
  8. Feb 14, 2020 at 8:48 AM
    Kilo Charlie
    Iowa
    Yea.. the ones I was using i the photos above are the strip type ones... a fairly cheap brand I found at the local Menards.
    on a side note.. this looks pretty bad ass https://shop.snapmaker.com/products/snapmaker-2-0-modular-3-in-1-3d-printers though it's not available until the end of this year.
  9. Feb 14, 2020 at 9:39 AM
    Kanyon71
    MI
    That’s pretty cool but I wonder about in being a multi in one. Yes they use the same motions and stuff but laser is very picky about some of the components so it makes me wonder if it’s good at all or just decent.
    Ya the LED’s range in price the diffuser is just a tube that’s flat on one side that you slide the LED strips you have into them. That way you can use whatever you want for LED strips themselves.
  10. Feb 14, 2020 at 9:50 AM
    Kilo Charlie
    Iowa
    What are your thoughts on the etched LED panels
    Something like this
    but the lexan/plexiglass whatever is lain on top of the shelf flat and likely lit form the back simply to hide the wiring?
    trekker and bvbull200 like this.
  11. Feb 14, 2020 at 9:52 AM
    USMC - Retired
    Gunns
    Ty Ty, Georgia
    2018 DCSB Quicksand
    I don't think that would make a very sturdy door... :laugh:
  12. Feb 14, 2020 at 9:53 AM
    Kanyon71
    MI
    We have one that’s a night light type of thing for my daughter. It’s a horse one. It looks pretty good and she like it’s.
    It’s glows but doesn’t cast a lot of light that that may somewhat of an issue.
  13. Feb 14, 2020 at 10:07 AM
    Kilo Charlie
    Iowa
    I was thinking it could be more of a cool looking diffuser. It may depend on the design and the clarity of the material too.
    Kanyon71[QUOTED] likes this.
  14. Feb 14, 2020 at 10:33 AM
    Kanyon71
    MI
    Try getting a tube of the LED strip diffuser to slide your current LED's into. Also run them down the sides of the shelf. If you want to uplight you and always hide them in the base or something. Try and and down lighting though I think you will have the best results with the down lights for an even spread. Then you can do the LED's into the lexan/plexi for nothing more than a cool effect and you don't have to worry about it lighting everything for you.
    I'm planning to use plexi for a halloween lighting project to help diffuse and spread light for a set of scary eyes.
  15. Feb 14, 2020 at 1:17 PM
    #35
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    I have something like that for my BBQ team. They look pretty sweet. The thing it completely framed in.
    It's only lit from the bottom, which makes the bottom of the design noticeably brighter than the top, but it looks good, still. Ideally, I'd have strips on the top and bottom - depending on the side, I'd put them on the sides, too.
  16. Feb 14, 2020 at 2:02 PM
    #36
    Kilo Charlie
    Iowa
    What if it was laying flat on the shelf and lit from all 4 sides ?
  17. Feb 14, 2020 at 2:38 PM
    #37
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    The effect you see in the picture you posted is because the LEDs shin in to the edge of the acrylic. If it bled over, it might look a little different, but I don't know. I think a frame (even a thin one) around it is ideal, but you could try it out.
  18. Feb 14, 2020 at 2:46 PM
    #38
    Kilo Charlie
    Iowa
    I guess I am just going to have to try it and post the results. I have an idea in my brain that I cannot put into the right words
  19. Feb 14, 2020 at 3:00 PM
    #39
    USMC - Retired
    Gunns
    Ty Ty, Georgia
    2018 DCSB Quicksand
    Took another picture to show how the door works. I also have LED lighting. Does all sorts of colors and effects (strobe etc). I tend to just leave it red...
  20. Feb 14, 2020 at 4:25 PM
    #40
    Kilo Charlie
    Iowa
    Definitely like this!
