Whiskey Cabinet BS
Discussion in 'Off-Topic Discussion' started by Kilo Charlie, Feb 11, 2020.
  1. Jun 10, 2020 at 5:53 PM
    #701
    Kilo Charlie
    Kilo Charlie [OP] Disruptor
    Iowa
    2017 Inferno Off Road
    It's some weird battery too.. I've actually looked at several places and no luck so far.
    wilcam47 likes this.
  2. Jun 10, 2020 at 5:54 PM
    #702
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Looking really good.
  3. Jun 10, 2020 at 5:54 PM
    #703
    Kilo Charlie
    Iowa
    Thank you sir!
  4. Jun 10, 2020 at 5:58 PM
    #704
    Kilo Charlie
    Iowa
    It's a bracket mounted to the top and then against the wall to hold the top securely
    trekker and wilcam47[QUOTED] like this.
  5. Jun 10, 2020 at 5:59 PM
    #705
    Kanyon71
    MI
    Should mount against the wall then slide shelf in and then screw down into the cabinet. Will hide the majority of the bracket from eyesight.
  6. Jun 10, 2020 at 6:14 PM
    #706
    Kilo Charlie
    Iowa
    Well two things... It's made of clear plastic so it's not easily seen and there was already a drywall anchor there .. otherwise I would have used your brilliant idea
  7. Jun 10, 2020 at 7:10 PM
    #707
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Did you get my alerts for that? :rofl:
    Looks awesome! The grey turned out grey-t... Great... Get it... :laughing::rimshot:
  8. Jun 10, 2020 at 7:14 PM
    #708
    Kilo Charlie
    Iowa
    Haha !
    I was thinking earlier that awhile ago I edited the name of this thread.. maybe that's why it's wonky on the alerts? Like maybe unwatch it then watch it again?
  9. Jun 10, 2020 at 7:19 PM
    #709
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    My liver hurts looking at it...lol jking good job
  10. Jun 10, 2020 at 7:23 PM
    #710
    Kilo Charlie
    Iowa
    Your liver shouldn't hurt from the full bottles.. now.. if I posted a picture of the empties... :rofl:
  11. Jun 10, 2020 at 7:26 PM
    #711
    Misplaced Nebraskan
    Zach
    Austin
    Not sure if you have "like" alerts on.
    I liked and unlocked and reliked that post a few times :D
  12. Jun 10, 2020 at 7:31 PM
    #712
    Kilo Charlie
    Iowa
    Haha nope.. I think the only alerts I have on are when someone tags me with the @
  13. Jun 11, 2020 at 4:27 PM
    #713
    Kilo Charlie
    Iowa
  14. Jun 11, 2020 at 4:51 PM
    #714
    Kilo Charlie
    Iowa
    @Georgeee28 - may have to take you up on that JD Rye 375ml... That shelf is looking weak!
    Georgeee28, trekker and wilcam47 like this.
  15. Jun 11, 2020 at 4:54 PM
    #715
    wilcam47
    Will
    Bourbon state
    But but they are still full...:rofl:
  16. Jun 11, 2020 at 5:47 PM
    #716
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Looking good man!
  17. Jun 11, 2020 at 5:52 PM
    #717
    Kilo Charlie
    Iowa
    That's the whole point!!
    Thank you sir!
  18. Jun 12, 2020 at 3:40 PM
    #718
    Kilo Charlie
    Iowa
    So in preparation for a new project I figured I would replace the rotting plywood on the miter saw stand that I acquired with the saw.
    As always... Easier said than done...
    As I said.. the stand came with the saw and it appears to have been made by the previous owner. Should be easy to pop off the wood and replace with new and get going on the new project.
    Unfortunately, the "builder" of said stand .. RIVETED the wood to the frame. After a couple of attempts to drill out the rivets I ended up grabbing the grinder and grinding off like 40 or so rivet heads.
    As you can see in the above picture the wood on the bottom shelf was under the metal, but since I was replacing it and wasn't going to use rivets... I actually had to take off one of the legs to get the bottom shelf piece of plywood inserted. As you can also see.. the bolts were rusted AF and it took a bit of WD-40 and my impact driver to get those out. All told a 5 minute job took me close to 4 hours.. not that I was working at a fast pace or anything. In the end the new plywood looks great and is attached from the bottom with wood screws in case I need to change it again... Or the next guy hahaha
    wilcam47, Bigdaddy4760 and Kanyon71 like this.
  19. Jun 12, 2020 at 6:12 PM
    #719
    Georgeee28
    Georgeee28 Well-Known Member
    George
    Central Coast Cal
    I can go snag it for you if you’d like? Shoot me a pm
  20. Jun 21, 2020 at 4:01 AM
    #720
    Kilo Charlie
    Iowa
    For those of you helping me in my quest, here's an updated list f what I am searching for. The ones with the question marks are ones I haven't been able to confirm even exist. Thank you in advance!
    trekker likes this.
