Whistle / high pitch noise - post accident sound. Looking for ideas.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by disel_V1, Mar 16, 2022.
  1. Mar 16, 2022 at 6:24 PM
    disel_V1
    disel_V1 [OP] I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Hey y’all.
    If you don’t mind reading this, I’d love your feedback. I’m losing my mind here.
    So long story short.. my truck was hit by a deer. The fender was messed up, mirror knocked off and passenger window cracked.
    All that has since been repaired.
    Post repair.. I noticed two things.
    1. My 6x9 speaker is suddenly blown
    2. I have a whistle that I hear when I’m going 50-60ish. (Have not gone faster than that since to test further)
    It’s odd that the speaker is blown suddenly, I feel the shop may have accidentally done it, but of course they take no responsibility. Regardless, I have two need speakers on order.
    I’ve checked the weather sealing and everything looks right. There is a SLIGHT little gap on the fender by the weather sealing. I’m unsure if that would cause the whistle. Im also unsure if a blown amp can somehow create a whistle when I’m accelerating. Mainly because more gas doesn’t necessarily mean mean electricity, right? Issue with the whistle happens with the radio on or off. Occurs when I’m in neutral, I’m fairly confident it’s not engine related. It’s not obnoxiously loud, but my god.. it’s at just the right frequency to where it’s noticeable and annoying as hell.
    If anyone has any bit of advice on where I can start… I’d love to figure this out. The shop is dismissive and claims the repairs shouldn’t have caused that. Stick my the truck to the body shop neither of those issues persisted. Either or, I just want to try and fix the whistle.
    Thank you so much.
  2. Mar 16, 2022 at 6:27 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Start by putting a piece of tape over the area you think there is a gap. See if the sound goes away.
    disel_V1[OP] and Dm93 like this.
  3. Mar 16, 2022 at 6:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Only thing I can suggest is maybe put some painters tape over the suspect area and see if the noise changes or goes away.
    disel_V1[OP] likes this.
  4. Mar 17, 2022 at 1:13 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    So if you find with tape it is not the door/door window seal try the windshield area.
    Possible if hit was harder than you/they thought and an area that often came with too little sealer holding the windshield in.
    This was a common problem on some gen2s with the Baja production code but that's another story (kazoo noise).
  5. Mar 17, 2022 at 8:41 AM
    disel_V1
    3rd Gen
    hey! That’s a great idea! If it were a windshield that was loose.. any ideas on DIY service? Or should I get like… safelight to repair it lol?
