Whistle in park/neutral
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbelisle, Apr 27, 2020.
  1. Apr 27, 2020 at 8:24 AM
    cbelisle
    cbelisle [OP] Member
    Hey guys, I've got a weird sound that's recently developed. It only happens once the truck is hot and only happens in park or neutral. I turned on and off the fan and AC and those didn't change anything. Turning the wheel didn't change it either, so I don't think it's anything to do with the power steering. It sounds exactly the same as this 4runner:
    https://www.youtube.com/watch?v=kcmyAqIiBXs&feature=youtu.be&app=desktop
    Any ideas? I don't have any engine mods and 140k miles. All fluids have been replaced over the past year or two. My first thought was the belt bullies, but it doesn't sound like it's coming from that area. I do have new pullies on order since I haven't replaced them.
    Thanks
  2. Apr 27, 2020 at 8:31 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    belts and pulleys 100%
  3. Apr 27, 2020 at 8:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Try this if you want to isolate it to the specific pulley. Hopefully it's an idler making this noise and not something more expensive (like an alternator bearing or PS pump bearing).
  4. Apr 27, 2020 at 8:56 AM
    cbelisle
    Right on, really hoping it's a pully. I'll keep you guys posted once I swap them out. Should be here Wednesday or Thursday.
    Cheers
  5. Jul 6, 2020 at 4:26 PM
    cbelisle
    Been a while, but still have the noise. I replaced the pullies (all 4) and although they needed replacing, the noise is still there. It only seems to happen once the truck is up to temp. Turning the wheel and running the AC or fan seem to have no effect on it. And again, it only happens in P and N. Any other thoughts?
    Thanks
  6. Jul 6, 2020 at 5:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you give the truck a little gas and raise the RPM the same amount as in P or N, does it still do it? You will need a buddy you trust to help you.
    Maybe it’s Transmission related, if it does not still make the noise?
  7. Jul 6, 2020 at 5:38 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Have you changed the belt?
    Try taking a spray bottle with water and spray the belt on a pulley while it's making the noise. If it goes away, you can be pretty sure it's belt related
  8. Nov 13, 2020 at 2:06 PM
    cbelisle
    Following up here. Still have the noise going on. I changed the belt, and when I rev the engine it goes away but then starts again as soon as the rpm's get back down to idle. It only happens on long drives too, such as camping trips where I'm driving for several hours. I'll never hear it around town or sub-30-minute drives. It does sound like it's coming from the transmission though.
  9. May 19, 2024 at 12:10 PM
    kumar
    kumar New Member
    @cbelisle, I have the same issue for my toyota LC v6 2016. i keep like this since mechanics said, nothing to worry, since its not mechanical issue.
    Did you fix the problem?
  10. Jun 7, 2024 at 2:32 PM
    mohammad
    mohammad New Member
    @kumar @cbelisle any solution i am facing the same issue same noice in my lc
  11. Jun 10, 2024 at 1:28 AM
    kumar
    kumar New Member
    @mohammad
    im in doha, please give your contact if you are living in doha
  12. Jun 10, 2024 at 2:38 AM
    mohammad
    mohammad New Member
    @kumar
    Just pass me your contact i will whatsapp u
    Yes i Am leaving in doha
