Whistle on accelereation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2wheelintacoma, Aug 23, 2021.
  1. Aug 23, 2021 at 11:58 AM
    2wheelintacoma
    2wheelintacoma [OP] Member
    2008 Prerunner 6speed
    2008 Prerunner, 4.0 Liter, V6, Manual
    I have NO check engine lights on.
    Bluedriver does not read any codes.
    Called the dealership, they say it's nothing.
    The truck has a whistling sound on acceleration. Sounds like I have a turbo.
    What is going on?
    Checked for any issues with the air intake, can't find anything.
    Am I just going crazy?
  2. Aug 23, 2021 at 12:29 PM
    270 Well-Known Member
    Jeff
    California
    09 Dc 4x4
    I had this problem after I installed a joying head unit. It drove me crazy, so I put the oem back in. Not saying it’s your radio but maybe in the same vein.
  3. Aug 23, 2021 at 12:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it only do it under acceleration?
    Or cam you get it to do it when you are stopped, and just rev the engine?
    Are you running the stock air box?
    I’ve heard this same sound on “cold air” intakes.
    Any leak before the MAF sensor usually won’t throw a code, since it’s being metered.
  4. Aug 30, 2021 at 11:35 AM
    2wheelintacoma
    The only addition to the head until was a Bluetooth module that I placed behind the unit.
    I am running a stock airbox.
    Acceleration is fine.
    As long as the engine is on I hear the whistle.
    The whistle is only annoying because I am concerned, it is a leak behind the sensor.
  5. Aug 30, 2021 at 7:06 PM
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Could be an idler pulley, mine sounded like I had a supercharger.
  6. Aug 30, 2021 at 9:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the drive belt off and see if the noise is still there
  7. Aug 31, 2021 at 3:17 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Alternators tend to whine right before they fail. Check your charging system.
