Whistle sound at speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steinerdf, Mar 26, 2018.
  1. Mar 26, 2018 at 6:46 AM
    steinerdf
    steinerdf [OP] Member
    I wanted to reach out about some feedback to this issue. Essentially when it is windy and I'm on the highway it appears the stock radio antenna whistles. This happens frequent enough that I am looking for a good solution.
    I have a 2014 with Sat radio, no nav.
    I know the stock one screws off and I would replace it with something with no whistle but don't know any good options while still getting a good radio signal.
    Any thoughts?
  2. Mar 26, 2018 at 6:48 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    You sure it's the antenna? Mine was making a kazoo noise from the front drivers side door gasket.
    TacoGuy1995 likes this.
  3. Mar 26, 2018 at 7:25 AM
    TacoGuy1995
    TacoGuy1995 Well-Known Member
    Jared
    Collinsville, IL
    2014 Tacoma TRD OR DCSB
    I had the same issue from the front passenger door gasket. Toyota replaced both driver and passenger gasket under warranty. No issues since. I imagine that is what the OP is hearing.
    ChadsPride[QUOTED] likes this.
  4. Mar 26, 2018 at 8:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP is it a faint tea kettle whistle, or a loud kazoo sound.
    The fain tea kettle whistle comes from the hood to grill seal (there is a tsb for this) but it easily fixed with a 1/4in dripper pipe line ran through the top seal of the grill that touches the hood.
    The loud kazoo sound is made by the door seals.
  5. Mar 27, 2018 at 11:45 AM
    steinerdf
    It is like a whitsling sound when the wind blows hard. Might be the kazoo sound.
    How would I fix this of it is the door seal?
  6. Mar 27, 2018 at 11:48 AM
    ChadsPride
    I cut a slit in he seal and stuffed some plastic tubing in there (about 16" of it)
    Been silent ever since!
    SC2SC likes this.
  7. Mar 27, 2018 at 11:54 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I had the kazoo noise from my passenger front door. Toyota fixed it for free because I complained about it when the truck had less than 200 miles on it. When the tsb was finally released they fixed it. Been a year since and the kazoo noise is gone
    ChadsPride likes this.
  8. Mar 27, 2018 at 12:04 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I had to do that when the Highlander was 8 years old. Door seal leaked when it rained hard.
  9. Mar 27, 2018 at 12:48 PM
    ChadsPride
    Scary. I'm pretty confident the way I did it won't allow any leakage.
  10. Mar 27, 2018 at 12:53 PM
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I have the same whistle, only happens when I'm going like 80mph+ and while its windy af
  11. Mar 27, 2018 at 1:21 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wheel bearing whistling? Or Snow White and the seven dwarfs whistle while you work sound?
    Post a video if you can OP
  12. Mar 27, 2018 at 1:38 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Welcome to owning a tacoma. Lol there are fixes for the door seal whistle. I just live with it. It's only at around 85mph
  13. Mar 27, 2018 at 3:06 PM
    Bebop
    Nick
    Sounds like the kazoo noise to me. It happens at highway speeds in a crosswind condition. On long road trips I used painters tape over the passenger side door seam before I got the tsb stripping.
  14. Mar 27, 2018 at 3:25 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I've had it for years, just part of the personality of the truck at this point ha ha
  15. Mar 27, 2018 at 3:27 PM
    Bebop
    Nick
    I put up with it for a few years before the tsb. I thought the same thing. The kazoo noise was the sign to crank up the radio and jam out!
