Whistling noise at 45+mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4ondflr, Jun 17, 2019.
  1. Jun 17, 2019 at 7:22 PM
    4ondflr
    4ondflr [OP] Well-Known Member
    2002 Bagged Taco, 2013 Double Cab Daily
    Bagged, back half, sheet metal bed, custom paint, narrowed rear, 20’s
    i have a 12 double cab prerunner as my daily driver and it whistles until I’m ready to pull my hair out!! I can’t find it so I’m assuming at this point it’s the seal in the windshield is leaking or something. Is still has the factory windshield. I just inherited this truck about a year ago from my grandfather who I took to buy it new in 13.
    Anyone ever had an issue like this? Dont really want to pay to pull the glass and reinstall if it’s something else
  2. Jun 17, 2019 at 8:34 PM
    badger
    badger Well-Known Member
    07 SR5
    There are lots of threads about wind noise around the door seals, and some fixes. I would look there first.
  3. Jun 17, 2019 at 8:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Jun 17, 2019 at 9:11 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Door seals, I had that issue with my 05 and my 14. New door seals fixed my problem.
  5. Jun 19, 2019 at 12:58 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If it sounds like a kazoo add a piece of blue painters tape along the entire top of windshield covering the seal and see if it stops. Not enough sealer used on install at factory if that's it and dealer will reseal free - if not lift up the top edge of the seal and add silicon into space. A glass shop knows the problem and can fix quickly also. When mine cracked and I put a new windshield in you could see the lack of sealant in there under the glass and the installer knew the problem and did a full sealant application before dropping the glass in.
    TnShooter and Westside like this.
  6. Jun 19, 2019 at 1:14 AM
    FatTexan
    FatTexan Well-Known Member
    Oundle, UK
    2015 Tacoma SR5 DCSB 4X4 Super White
    I tack down the highway like I'm sailing a boat, not the safest option and it seems to upset other drivers but it works.
  7. Jun 19, 2019 at 1:24 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I believe there is also a TSB for door seals on the double cabs, it's for a "reed/buzz" type noise.
  8. Jun 19, 2019 at 10:58 AM
    4ondflr
    Yea I contacted my service advisor friend to see if she could pull some string and possibly get it covered..... FAIL!!
    I’m gonna try covering different areas with tape (windshield, hood, door seals) and see if one stops it and try replacing that seal
  9. Jun 19, 2019 at 11:11 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OK, first answer this. Is it a faint tea kettle whistle, or a kazoo sound.
    Once answered I can tell you what it is.
    Clearwater Bill likes this.
  10. Jun 19, 2019 at 12:45 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Per someone else's suggestion, I used some rubber vacuum tube and pushed it into the gap/void on the front face of the seal. I used about a 40" long piece (that's what I had on hand) and centered it equally using the rear-view as my center point. Stretching the tube makes it thinner and easier to install. Some said to use soapy water to help install it.
    It worked, the noise stopped and I have since removed tubing and the kazoo noise has not returned. Probably due to the seal aging and becoming less pliable.
  11. Jun 19, 2019 at 1:04 PM
    nd4spdbh
    SoCal
    There are a few sounds.
    1 faint tea kettle whistle
    and 2 kazoo.
    As response to my post above.
    Faint Tea kettle whistle has to do with the gasket at the top of the grill center where it meets the hood (about 3 foot long). Put a piece of 1/4in dripper pipe inside the gasket and the tea kettle whistle will go away.
    1st kazoo sound is the windshield gasket. This is easily diagnosed by a change of pitch / stopping of the sound when you push on the windshield while its happening.
    2nd kazoo sound is the door seals, not easily diagnosed, but easily fixed with again some 1/4in dripper pipe laid inbetween the folds of the door seal.
  12. Jan 9, 2021 at 2:02 AM
    4ondflr
    This fixed mine, I finally got around to putting the 1/4” tube in the seal at the top of the grill between the hood and it did the trick. Thanks.
    nd4spdbh[QUOTED] likes this.
  13. Jan 9, 2021 at 7:43 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I had a "kazoo" sound at speeds above 40 mph. Checked all the door seals. Found the seal on the left rear door of the Access Cab to be damaged.
    Ordered the part from Toyota. Pulled off the old piece, snapped on the new piece......."kazoo" plays no more.
    Check your door and window seals. Any damage or stiffness or deformation will sound off crying for attention.
