Whistling noise from HVAC system...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011Streaker, Jul 13, 2014.
  1. Jul 13, 2014 at 1:17 PM
    2011Streaker
    2011Streaker [OP] Well-Known Member
    Maine
    2012 DCSB TRD Sport
    I have a whistling noise that is consistent with the fan speed for the blower motor. The noise is coming from behind the dash on the passenger side. Ive already had the TSB done and this is NOT the chirping.
    Its a straight whistle. it goes away if I open a door, roll a window down, or remove the particulate filter. I ordered a filter from rock auto today in case that's the culprit, but didn't know if you all had any other suggestions?
    Thanks
  2. Jul 13, 2014 at 4:06 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Well since it goes away when you open a door (or window?), I'd it might be related to the pressure in the vehicle when the fan is on. One thought, Is it possible you have a tiny hole in the area leading to the outside (i.e. firewall or floor under the dash possibly from a missing screw or access hole/missing plug)? IT may be whistling as the pressure pushes the air outside the car?? I'd also check the blower housing for the same...
  3. Jul 13, 2014 at 4:07 PM
    2011Streaker
    Maine
    2012 DCSB TRD Sport
    it has to be pressure related as u said. i attributed it to a dirty filter since it goes away when the filter is removed.
  4. Jul 13, 2014 at 4:13 PM
    medic2230
    Murph
    Bama! Roll Tide
    Leaf or something caught in the area with the filter and whistling as the air goes past it?
  5. Jul 13, 2014 at 4:47 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Check you cabin filter cover sounds like it wasn't installed correctly or came a little loose I have seen that a few times
