Whistling Noise in Crosswinds At Highway Speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunlobbyist, Jan 6, 2014.
  1. Jun 24, 2015 at 4:39 PM
    #181
    GotMetal
    GotMetal Well-Known Member
    2010 TRD Sport DCSB
    Chizel07 and NMTrailRider like this.
  2. Jun 24, 2015 at 6:14 PM
    #182
    Nibs1964
    Nibs1964 Member
    NW Ohio
    GotMetal, that looks like a good product to place into the existing seal. I continue to monitor your post as i find them very helpful and believe your getting very close to solving this annoying sound.
    Thanks again and cheers!
  3. Jun 24, 2015 at 7:56 PM
    #183
    GotMetal
    2010 TRD Sport DCSB
    Thanks man. I hope you're right. It should not only make a better seal but also secure it up in there better and not allow it to move side to side, which I think could be causing the noise.
    This is what I think is happening. When the winds hit the passenger side, for example, the pressure inside wants to exit the drivers side. With the window closed, that pressure is pushing outwards on the window, moving it ever so slightly and creating a little gap to escape through, thus the noise. This would also explain why the noise is stopped by pushing on the window. You're resealing that gap against the rubber. I may be way off here, but it makes sense to me.
  4. Jun 24, 2015 at 8:08 PM
    #184
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Im going to go browse the adhesive section at a couple hardware stores tomorrow. There was this clear/transparent rubbery tape I put along the front edge of my hood when i installed my weathertech bug shield. It protects the paint where it is in contact with the plastic deflector. It's almost like that clear stuff they try to sell you at the dealer for protecting the front of the car. I'm thinking about putting something like that along the top edge of my window. Out of sight when the window is up, as long as it's a narrow enough strip. I noticed today that I could hear air causing a sound from that location on the window while just driving around town today. Not the full blown whistle, but a definite sound of turbulent air. If I pushed out on the top of the window the sound would stop, but it gradually came back after about a minute. My other windows are silent.
  5. Jun 24, 2015 at 8:13 PM
    #185
    GotMetal
    2010 TRD Sport DCSB
    Cool, I'm interested in what you find.
  6. Jun 30, 2015 at 11:32 AM
    #186
    motozack
    motozack Well-Known Member
    zack
    Humboldt Ca.
    '07 2015 TRD pro clone MAGNUSON supercharged
    Magnuson S/C 2.85 stealth pulley Afe stage 2 sealed pro dry 255 URD fuel pump TRD Quickshifter & knob Method double standards 265/70/17 KO2's B.A.M.F. Sliders W/kickouts powder coated 2.5" kings W/resi's Camburg UCA's TRD catback exhaust 2015 TRD pro clone 2015 interior Pioneer Nav
    You just run screen spline along the upper weather stripping of the windshield. There is an opening that it fits perfectly into. Problem solved
  7. Jul 4, 2015 at 10:40 AM
    #187
    GotMetal
    2010 TRD Sport DCSB
    I'm going to try the spline trick. The stuff I bought for the window seal did not work. On to the next.
    Zack, do you know what thickness you used? When looking this stuff up it seems there are several sizes available. Thanks.
  8. Jul 4, 2015 at 10:37 PM
    #188
    NMTrailRider
    New Mexico
    I was unable to find the clear plastic/rubber adhesive tape. but got metal's weather stripping gave me an idea. I found some open cell one-sided adhesive weather stripping that is really soft. lots of loft but compresses to near flat. I'm going to try it in the groove where the window sits up top. the collapsibility will allow the window to close within about 1/50 of an inch of normal and the loft should fill in any gap. just need to get out on the open road with a stiff breeze.
  9. Jul 4, 2015 at 10:41 PM
    #189
    GotMetal
    2010 TRD Sport DCSB
    Excellent. Let us know how it goes.
  10. Jul 8, 2015 at 7:46 AM
    #190
    GotMetal
    2010 TRD Sport DCSB
    That's the noise I have as well. A few of us have been trying different things, to no avail. My next attempt is motozack's screen spline trick, which I have done but not tested in any winds yet. He said it worked for him, so we'll see. Also waiting for harpolith's update.
  11. Jul 8, 2015 at 7:55 AM
    #191
    deadoffall
    deadoffall Member
    dan
    2014 Gray Tacoma
    16x8 Helos with 265/75r16 Cooper AT3 2" leveling kit in front, 1" blocks in back
    Today I reached across and pulled on the passenger door as it was making the noise and it seemed to quiet down. The hardest part seems to be figuring out exactly where the noise is coming from. I've already been planning on putting a windshield in it anyway. So maybe that will help rule out that.
  12. Jul 8, 2015 at 8:35 AM
    #192
    GotMetal
    2010 TRD Sport DCSB
    For me, and some others here, it seems to be in the upper window area where the top starts to slope down. We can push on the window from the inside in this general location and make the noise stop. What it causing it is the more troubling part for me.
  13. Jul 8, 2015 at 10:15 AM
    #193
    deadoffall
    deadoffall Member
    dan
    2014 Gray Tacoma
    Pretty sure I've found the problem I'm experiencing. Might be able to help some of you guys.. The factory windshield was installed ever so slightly crooked. So the gap between moulding and A pillar on the driver side is much smaller than the gap on the passenger side.. Which is allowing air to force the moulding to flip backwards while driving into a strong wind.. Which causes the sound of letting air out of a balloon. I'm having a buddy back fill the moulding with urethane today to see if that helps keep the moulding in place.
    Chizel07 likes this.
  14. Jul 9, 2015 at 2:54 PM
    #194
    deadoffall
    deadoffall Member
    dan
    2014 Gray Tacoma
    No noise today after throwing a bunch of urethane behind the windshield moulding.. Hoping it stays that way!
  15. Jul 9, 2015 at 4:30 PM
    #195
    GotMetal
    2010 TRD Sport DCSB
    That's great! My windshield is not as you describe. Not crooked. Looks pretty even all the way around. The screen spline I tried did not work. Not surprised though. I didn't really think it would.
  16. Jul 9, 2015 at 4:53 PM
    #196
    deadoffall
    deadoffall Member
    dan
    2014 Gray Tacoma
    Have you tried using an air compressor and blowing air into the windshield mouldings? That's what lead me to realize what was going on.. by crooked I'm talking like 1/16 of an inch off.. Super small amount. But just enough to let the moulding lip fold along the a pillar and allow air in.. Kind of hard to explain
  17. Jul 9, 2015 at 5:00 PM
    #197
    GotMetal
    2010 TRD Sport DCSB
    I know what you mean. Yes I have tried compressed air all over the windows, side mirrors and windshield. The only ones I could find noise in was the mirrors and windows, nothing in the windshield.
  18. Jul 25, 2015 at 3:36 PM
    #198
    ltharley
    ltharley New Member
    2015 Tacoma DBL Cab TRD Off Road
    I have a 2015 Tacoma Dbl Cab and have same howling noise that sounds like it is from driver's mirror at high speed with crosswind. If I fold the mirror it stops. I put Weathertech side window deflectors on and it greatly reduced the frequency and volume of the sound. Still not happy though. Want it totally gone.
    Spixelz likes this.
  19. Sep 30, 2015 at 9:36 AM
    #199
    MaritimerNB
    MaritimerNB Well-Known Member
    23 DCSB-6MT TRD Pro
    Tonneau, Sequential Mirror
    Sub'd. 2 week old Tacoma DCLB and with cross wind or higher speed it is driving me insane.
    waj30 likes this.
  20. Sep 30, 2015 at 1:04 PM
    #200
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Mines definitely doing it from the top of the windshield. I was going about 80mph when I just started to hear it so I started pushing on the upper part of the windshield and it would change as I pushed on it. Sometimes I could make it do it by pushing on it. So I'm thinking some good sealer around the windshield should do it for me. When you say back fill what do you mean? I'm thinking of just running a bead around the seal? I did a video and will try to post it later.
