Whistling Noise in Crosswinds At Highway Speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunlobbyist, Jan 6, 2014.
  1. Jun 25, 2014 at 4:45 PM
    #61
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like its not the window but the actual door seals.
  2. Jun 26, 2014 at 5:54 AM
    #62
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
  3. Jul 10, 2014 at 9:20 PM
    #63
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    So I drove 3600km across canada at up to 150kph no more noise after 4 years it was the windshield trim/moulding. I paid out if pocket for it because I was starting to hate my truck.cost me $275 with parts.
  4. Jul 30, 2014 at 5:55 PM
    #64
    nmtaco13
    nmtaco13 Member
    Albuquerque
    2013 Tacoma Offroad
    Snug Top Shell BFG AT KO2 tires Full OME suspension
    I had the same windshield noise on my 2013 TRD Double Cab. Dealer reinstalled windshield with new kit. It helped but did not completely solve the problem. I still get the whistling noise, although not as loud, with cross winds and driving at highway speeds.
    I plan to bring this up again at my next servicing which will be at 20k sometime in the late fall 2014.
  5. Jul 31, 2014 at 4:15 AM
    #65
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    Just had my windshield removed and re-installed at the Toyota body shop so they could replace the headliner. First day since I got this 14 DC back and now I have a whistling whine which seems to come from the top of the windshield at highway speed. This is different than the noise I had in high crosswind. I can feel the vibration at the top of the windshield and it wasn't there before. Hauling it back to them today. Jeez!
  6. Jul 31, 2014 at 4:18 AM
    #66
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I had a noise similar to that with highway speeds and a crosswind. Turns out it was just how the wind was hitting the grooves of the antenna.
    Which reminds me, I need to get a stubby.
  7. Jul 31, 2014 at 12:49 PM
    #67
    Balien
    Central Canada
    I strongly suggest anyone with this sound get the new windshield moulding/trim installed while your on warranty windshield re-sealing doesn't do anything until they change the moulding.
  8. Oct 13, 2014 at 1:23 PM
    #68
    belfly
    belfly New Member
    al
    indiana
    trd off road
    cai, soon will add banks monster exhaust
    I used an air nozzle and discovered the air noise is the window. exact same noise as kamdag. mine is on passenger side. couldn't get it to repeat on driver side.
    but over and over again on passenger side. the difference I see is the driver side seal
    has a raised area all the way up the channel towards the outside of the truck.
    the pass. side it is flat all the way up. either not right seal or shifted or something.
    my suggestion if dealer said repaired but noise is there take it back and have them use an air nozzle. then have them repair it. mine is under the extended warr. now that i know what is causeing the noise. I don't if they will repair it. then I will have to find another solution. ( the seal deforms under air pressure) I might epoxy a rubber strip on to block and strengthen seal.
  9. Dec 25, 2014 at 8:30 PM
    #69
    trdtoydriver
    trdtoydriver Active Member
    Washington
    2014 B. Red Baja TRD TX
    I have the same sound and it does sound like it is coming from about the mirror height of my driver door going down the road at 83 with a little crosswind. I had time to mess with it while I was driving and what I noticed was if I just barely hit the window down button it goes away immediately. When I say down barely the window is not even cracked open but still in the upper groove. Probably less than a mm down action with no wind felt then as soon as I snug up the window it would start again. I did this over and over as a test and every time the sound would go away when just bumped down and would come back when window was snugged up. I don't know what to do about it or what would cause that so if anyone has an idea I am listening? I will probably ask dealer but it sounds like I won't get far. I will look at all the door seals but I don't know how that would relate to the window snugged or not.
  10. Dec 26, 2014 at 2:28 PM
    #70
    wyomingblazer
    wyomingblazer Member
    Stan
    Cheyenne, WY
    2014 Access Cab SR5
    I wonder if "in channel" window deflectors would solve the problem?
  11. Dec 28, 2014 at 10:23 AM
    #71
    trdtoydriver
    Washington
    Yes, maybe but I never planned to put those on. On another note it does look like weathertech has made some really nice low profile "in channel" ones now. I will keep it in mind. Thanks
    I also watched a video on some forester Subaru which I guess they have had a lot of wind noise issues with the door seals (mainly around what the guy in video called the gusset which may be issue) and I have an appointment with dealer. I am guessing I will have to solve the problem on my own since dealer already acted like they never heard of the issue. I told him that is funny since it posted all over the internet even with videos of the noise.
  12. Dec 29, 2014 at 9:45 AM
    #72
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    My dealer says they can not duplicate this noise. Wtf.
  13. Dec 29, 2014 at 10:03 AM
    #73
    jmaack
    Justin
    Helena Alabama
    What can I tell them so they can fix it. I told them driving on interstate when wind blows. They tried taping stuff up but it wouldn't do it. I told them its only when wind blows it seems and today isn't windy. But they wouldn't listen.
  14. Dec 29, 2014 at 1:11 PM
    #74
    V0X
    V0X Well-Known Member
    Eric
    Ooltewah, TN
    TRD Pro Grille, MB TKO Wheels, BFG TA KO 265 70R17, Pop and Lock (color matched), Undercover SE Tonneau.
    I took my 2015 TRD Sport AC in today and the technician couldn't hear the noise during his test drive. The service adviser asked if I could drive the technician to replicate the condition. I drove him at 70+ MPH and the technician heard the whistling noise. He couldn't identify the source, but said that I would need to leave the truck for "days" so they can confer with Toyota for any prescribed solution.
    They told me that there are not TSBs for 2015 Tacoma's related to whistling noises heard in the cab. I mentioned the 2 previous TSB's and they acknowledged they were for earlier models.
    I'm now going to wait until they have a loaner vehicle for me so I can leave my truck for diagnostic. It may be a while as the dealer only has 4 loaners.
    Thanks,
  15. Dec 29, 2014 at 1:43 PM
    #75
    jmaack
    Justin
    Helena Alabama
    On the way back I went up to 85 and nothing. I will go again when we have some storms or wind so they can hang on to it for a few hours.
    I'm gonna try a compressor and see if incan replicate.
  16. Dec 29, 2014 at 3:30 PM
    #76
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I had this happen once on a longer trip with pretty wicked side winds. I have a video on my phone for evidence if I pursue a fix with the dealer. I was convinced it was the air vent and maybe the blower motor was going. The only way I could get it to stop was to turn the fan off or open the vent to allow outside air in instead of recirculating. It was a hot day and I had to decide between no AC or no noise. I went without AC as long as I could and then listened to tbe noise until it cooled the cab down again. It has to be windshield or door seal related. I could start and stop it by opening and closing the outside vent.
  17. Dec 29, 2014 at 3:40 PM
    #77
    jmaack
    Justin
    Helena Alabama
    I told them there is a YouTube video showing it but they didn't listen. They have to see it first hand I guess. Then tape stuff up to see if it goes away. Blah blah blah.
  18. Jan 2, 2015 at 4:34 PM
    #78
    trdtoydriver
    Washington
    Took it in to dealer today for a scheduled appointment. No crosswind and couldn't make it do it they said. No TSB's yet either so no fix from them. Got my seat belt dinger adjusted so it wasn't worthless. I will probably try some door seal tweeks when we have a cross wind day that I can make it happen over and over while I make changes. Let you know what I find then.....
  19. Jan 7, 2015 at 2:56 PM
    #79
    Chino Tom
    Chino Tom Member
    Tom
    SoCal
    13 Sport 4X4 Pyrite Mica
    Depending on the direction of the crosswind, the whistling happens on
    both driver and passenger front window. It happens ALL the time.
    By inserting a business card holder in between the door jam seal and the
    door will eliminate almost everytime on the driverside. It is hit and miss
    on the passanger side. Annoys the hell out of my wife. Me not so much.
  20. Jan 7, 2015 at 5:08 PM
    #80
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Posting here to subscribe, mainly. I have this issue as well, mainly on the passenger side. Sounds exactly like the other video posted and it's annoying as hell. Pressing against the passenger door glass from the inside makes it go away, and sometimes it goes away by cracking the window as described above. Definitely makes me think it's something in the window trim. I don't see any obvious gaps though, and the dealership hasn't been able to reproduce it. I'll upload my own video soon.
