Whistling Noise in Crosswinds At Highway Speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunlobbyist, Jan 6, 2014.
  1. Jan 19, 2015 at 1:57 PM
    #81
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    I've also had a problem with my '13 AC, an annoying whistling sound starting at about 35-40 mph. This and and other TW threads suggested bad windshield or hood seals, mirrors, antennas, etc. Some posters have suggested inserting tubing or thin dowel rods in the front hood seal, so I thought I'd try it.
    Purchased a 3/16" wooden dowel and cut to length.
    Rounded off ends with sandpaper to facilitate easier push through.
    Inserted through front hood seal.
    Took the Taco out for a test at highway speed and WOW! NO NOISE!
    I just love it when an easy and inexpensive fix works.
    Thank you TW!!
    tacotillie likes this.
  2. Jan 19, 2015 at 8:42 PM
    #82
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    tacotillie and optysite like this.
  3. Jan 19, 2015 at 8:52 PM
    #83
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    That sounds like aliens trying to contact you...
  4. Jan 20, 2015 at 1:08 PM
    #84
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I get the whistling too but only if I'm going 75+ mph. Slow down.
  5. Jan 20, 2015 at 3:23 PM
    #85
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Again there are two different distinct noises.
    The grill whistle that sounds like a faint tea kettle.
    And the kazoo noise made by most likely the door seals.
  6. Jan 20, 2015 at 3:43 PM
    #86
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I heard a similar noise the other day with a strong crosswind coming from about 4 o'clock. It was mildly irritating but went away as soon as the direction changed. I may mention it when I take it in for service but I'm not going to spend hours chasing down a fix.
    There's a saying in the BMW motorcycle forums you see a lot:
    "They All Do That"
  7. Jan 21, 2015 at 12:39 PM
    #87
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    The kazoo sound is usually the windshield molding/seal not the door seal. You are misleading people who dont know what's going on. If you push hard on the windshield from the inside near the top where the noise is coming from the tone will change if it's the windshield molding/seal. At least it did on mine. This issue has been clearly identified on this and several other threads and Toyota knows all about it but plays dumb like its the first time they have heard of this every time.
  8. Jan 21, 2015 at 12:46 PM
    #88
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I get the exact same noise and I had also fogured it came from the mirror
  9. Jan 21, 2015 at 12:58 PM
    #89
    Balien
    Central Canada
    Try pushing on the glass hard all allong the top especialy near the mirror towards the drivers side next time it buzzes. The rubber moulding vibrates in the Chanel at a certain wind speed and angle. If the sound changes. You need a new moulding. The mirror could be the problem but you would see the miror vibrating if it was. The kazoo is exactly how the windshield noise sounds. It's very loud too.
  10. Jan 21, 2015 at 1:48 PM
    #90
    nd4spdbh
    SoCal
    my windshield has been resealed and the kazoo noise is still present.
  11. Jan 21, 2015 at 2:31 PM
    #91
    Balien
    Central Canada
    Did they change the moulding when they resealed it? I had to get it done twice because the moulding was the issue they are suposed to change it but they don't allways do it. See my picture. The new molding is shaped differently.
  12. Jan 28, 2015 at 4:50 PM
    #92
    trdtoydriver
    trdtoydriver Active Member
    Washington
    2014 B. Red Baja TRD TX
    I hear what you are saying and I don't think a lot of us are trying to mislead anyone with the whining sound. Yours may of been the windshield molding but I still think mine is the door seals. The only way it couldn't be the door seal in my case would be if the door seals are so tight that it is causing some type of pressure in the cab and the windshield is then making noise that is sounding like it coming from the driver side mirror. I don't think this is the my case. Like I said earlier, I can make go away and come back by simply hitting the window down about 1mm or less so it is still pretty much closed and in the top track. The whine comes back once I snug it back up. My opinion is the window is ever so slightly making the top frame of the door move outward to cause the sound to start again when it is fully up or I am relieving pressure in the cab which I am not feeling any air when I have the window just barely bumped down. Mine does sound like the many videos where it is coming from about the side mirror height inside the cab when the window is closed fully.
    I see only a couple solutions since there isn't a real TSB for brand new Tacoma's yet. Either I can try the slight top door bend by pulling on it while the window is down (never tried it and wonder if works) from inside the door like I have seen in some videos or install some in the groove air deflectors which I think could create that little gap (maybe since I never wanted these or installed them before) that makes my noise come and go. Anyone installed the in groove deflectors and not had the noise again??
    My short term fix or maybe I will just live with this fix if it bothering me is to just bump the window down so it is still closed just not snug and I have no noise.
  13. Jan 28, 2015 at 8:25 PM
    #93
    Dunkoma
    Dunkoma <3
    Andrew
    Phoenix, AZ
    Tacoma TRD Sport 4x4
    Custom Avid Sliders, AFE Intake, Painted Magnaflow Exhaust, Debadge/Plastidip badges, Icon Extended Travel C/O + 2" Rear Shocks, Icon AAL, Sway Bar Delete, Bar caddy console organizer
    Posted in this a while ago - just want to add to what's already been said.
    Thought it was the mirrors at first - noticed pushing on the window stopped the 70+ an hour horribly loud noise, had the dealership change the outer window seals (not sure of the proper name) and so far so good :D
  14. Jan 28, 2015 at 9:55 PM
    #94
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    No. I have in channel window visors. Drove from BC to Saskatchewan and the crosswinds of the prairies had me ready to burn my truck. My father-in-law pinched the top of the passenger door closed tighter with the tips of his fingers and it would stop the noise. It is the sound of the wind hitting the gap between the door and the cab at the top corner and has nothing to do with glass.
    optysite and kgarrett11 like this.
  15. Jan 28, 2015 at 11:59 PM
    #95
    Echodawg
    Echodawg Well-Known Member
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    I can second this. I too had in channel visors and have had the same issue. Its also not the grill for me. Subbed.
  16. Jan 29, 2015 at 7:52 PM
    #96
    TexasJohn
    TexasJohn New Member
    Texas
    13 Red PreRunner SR5
    I had both the soft whistle noise and the loud screeching noise that's in the YouTube video posted on this stream. I did the 1/4 drain hose in the 3 front and main back hood seals and that cured the whistle noise. Toyota resealed my windshield but that did not correct the screeching noise. Next windy day I'm going to duct tape around the mirrors and the door seals to see if that stops it. I'm suspicious of the mirrors, but don't know for sure yet.
  17. Jan 30, 2015 at 5:30 AM
    #97
    jaymoussy
    jaymoussy Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Maybe I missed it (so much written on subject), but I never heard of the back hood seal (in addition to the well-known front) fix before.
    Same treatment as front, 1/4 hose?
  18. Jan 30, 2015 at 8:29 AM
    #98
    cleung
    cleung Well-Known Member
    Saskatchewan Canada
    07 TRD offroad DCSB
    Bilstein 5100, 265/75/16 tires, Extang solid fold
    I also get this exact noise but from the driver side. It sounds like its coming from the door somewhere and not the windshield. I have also had my windshield replaced twice so I"m guessing its not from that, and I have in channel visors and still get the noise. I don't get mine nearly as bad though, its pretty intermittent and only happens in strong cross winds going 70+mph.
  19. Feb 16, 2015 at 5:58 AM
    #99
    friendlyphil
    friendlyphil Member
    2015 Prerunner Dbl Cab. Barcelona Red. TRD
    I don't think that problem is from the mirror. My '05 Taco has been making it for years. If you press your hand against the passenger side window, the noise stops. When I wash the truck, I use some WD40 to lubricate the seals around the window and apply some to the top edge of the window itself. This helps a lot. But at the right speed (fast) and the right wind direction, that noise always comes back.
  20. Feb 17, 2015 at 2:10 PM
    #100
    TexasJohn
    Texas
    I had both noises too. Toyota resealed my windshield which wasted 2 hours at the dealership and did not correct either noise.
    Based on postings on this site, I corrected the whistling noise by inserting 1/4" tubing in the 3 front and one back hood seals.
    The other noise in the video on this stream is the seal on the door between the door and the A-Pillar. It can happen on both sides, but mine has only occurred on the driver's side. I temporarily corrected it with duct tape over the seal just to prove the source. I then put a thin adhesive backed weather strip from Lowe's or Home Depot on the A-Pillar to provide more pressure on the seal to prevent the airflow causing the noise. It's a cheap solution and since I go to Lowe's often it doesn't take any time like leaving your Taco at the dealer in hopes they can get the right cross winds in a test drive and then figure out where it's originating.
