Whistling noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dblj70, Apr 16, 2016.
  1. Apr 16, 2016 at 1:23 PM
    dblj70
    dblj70 [OP] Well-Known Member
    Jeff
    2013 DCSB TRD Offroad SpruceMica
    While driving when it's really windy I get a sporadic whistling noise that sounds like it could be coming from somewhere around the in-cabin air filter. Does this happen to anyone else?
  2. Apr 16, 2016 at 5:11 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    My '13 and '14 both did this. i fished a piece of 1/4" clear plastic tubing through the rubber hood gasket to fix it. It is also common for door gaskets and bug deflectors to cause this.
    Spray some fantastic spray cleaner or the likes inside the gasket, then push the tube right in. I did it across the hood and above the headlights.
    dblj70[OP] likes this.
  3. Apr 16, 2016 at 5:22 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    Is it a "tea kettle" high pitch sound? It may be the front hood seal as hotrod53 suggested, I did something similar as he:
    https://www.tacomaworld.com/threads...s-at-highway-speed.309795/page-5#post-9740410
    dblj70[QUOTED][OP] likes this.
  4. Apr 16, 2016 at 5:28 PM
    dblj70
    Jeff
    I guess it's kinda high pitched. I only notice it when it's really windy out though. I'm going to take y'all's advice and try pushing something through that gasket. I think I have some plastic tubing laying around from an aquarium.
  5. Apr 16, 2016 at 5:34 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I also whould here that same whistling nose when I had the radio turned down, I ask my wife if she could here it. She said no and went back to sleep. Then I heard it again. Then it dawned on me, it was her. I now keep a box of those breath right strips in the glove box and anytime she rides in my truck she has too put one on her nose. That fix the problem and it was a cheap mod to boot.
  6. Apr 16, 2016 at 6:09 PM
    dblj70
    Jeff
    Mission accomplished. I pushed some tubing through the seals. The ones above the headlights went right through but the one across the hood was a p.i.t.a. Almost gave up and went to go get a wood dowel. I got it within an inch of the other side and then grabbed it with some tiny needle nose pliers and pulled it the rest of the way. Now I'll see if it worked on the next windy day. Thanks for the help guys.
  7. Apr 16, 2016 at 8:33 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah let us know if it helped.
  8. Apr 17, 2016 at 6:59 AM
    hotrod53
    Lynd
    Pittsburgh, PA
    If it were a PITA you needed more spray cleaner. Fantastic spray cleaner worked great for me, pump that stuff right in there from both ends good and heavy, it will dry up. I like the idea of plastic tubing over the rigidity of the dowel because there isn't much room and that gasket needs to squeeze to seal.
  9. Apr 17, 2016 at 7:05 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Ah .... Background wife noise...... LOL
  10. Apr 17, 2016 at 7:07 AM
    Jahawkbill
    Jahawkbill Well-Known Member
    2015 MGM DCSB TRD Off Road
    Bilstein 6112s/SPC LR UCAs/Bilstein 5160's/ICON 3 leaf Pack/FJ Trail Team 16x8's/Cooper ST MAXX 255/85/16
    Same issue here, I'll give the 1/4 in tubing a try. Results to follow.
  11. Apr 30, 2016 at 1:07 PM
    PVGWhite
    PVGWhite Member
    Greg
    03 TRD 4x4
    Once again, this is the place to come for accurate info! I have been putting up with the highway whistle for a couple years since I couldn't convince anyone to hang onto the hood at 70 mph to locate where the noise was coming from. I just slid in a piece of aquarium tubing as directed, and hit the highway with a quieter truck. Mine is a 2003 that just went over 100k miles, so it's just getting broken in!
    Thanks everyone
    hotrod53 and dblj70[OP] like this.
  12. May 4, 2016 at 8:15 PM
    dblj70
    Jeff
    OK, it's been almost three weeks since I put the aquarium tube in the gaskets and have yet to hear anymore whistling. We had some bad thunderstorms last week with pretty good wind and so far so good. Taking a road trip this weekend to Tennessee so I'll see how it does on the interstate.
  13. May 5, 2016 at 5:02 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    May be a dumb question in relation to this thread, but for any of you that had this issue which was remedied by beefing up the under-hood gasket... would opening your window stop the whistling?
    I have a high pitched whistle sound, only on a windy day, only at speeds of 40MPH+ that sounds like it's coming from the driver's side, but if I crack my window down enough to let air in, the whistling instantly stops. I'm thinking it may be a window gasket issue because it only started making the noise here in the past 2 months, but I'm wondering if the gasket under the hood could somehow be the culprit?
    Thanks.
  14. May 5, 2016 at 1:39 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    There are a lot of reports of door gasket issues, I'm guessing that's what your problem is. I would suggest taping off around your door jamb on the outside with blue painters tape and going for a ride to see if it resolves, then you'll know.
