Whistling noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bell13tacoma, Mar 30, 2021.
  1. Mar 30, 2021 at 7:57 PM
    Bell13tacoma
    Bell13tacoma [OP] Member
    James
    2013 Grey Tacoma Prerunner
    Hey guys. It's been a long time since I have been on here but I am hoping for some help. My 13 tacoma 2wheel dr. 2.8l has a whistle while running and gets quiet as it warms. Any ideas.
  2. Mar 30, 2021 at 8:09 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Leaky engine gasket? When it heats it reseals? My Wrangler did that. Then started to drop oil pressure at idle. Normalized when combustion resumed. Just a guess though.
  3. Mar 30, 2021 at 8:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It could be a lot of things... But a leaking vacuum hose or an intake gasket are very likely candidates.
    Get a can of carb cleaner and using the tube nozzle spray it around the intake runner where it connects to the head. If you hear or see a change in the engine idle or the whistling stops momentary then that is where the leak is.
    6 gearT444E likes this.
  4. Apr 4, 2021 at 12:31 PM
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    Is it very loud? And while you're driving? This isn't really advice but maybe piece of mind if it sounds similar to mine. Mine whistles sometimes. It's done it for a while, I think it's just the throttle body. I'll hear it sometimes when I step on the accelerator. It's faint. Usually makes a whistle/wine on a cold start too. Throttle open to run rich for the first few minutes combined with the 2ndary air injection system. The 4 bangers are just kind of rough/loud engines. Cleaning the throttle body might help.
