White “corrosion” on engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JARStacoma, Feb 19, 2018.
  1. Feb 19, 2018 at 10:20 AM
    JARStacoma
    JARStacoma [OP] Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Yesterday I got back after an extended three month vacation. I stored my truck in my neighbors covered car port with the battery disconnected. I live in Alaska where it has been obviously cold this past winter but on the coast so not as cold as say the midwest. However lots of moisture in the air. When I popped the hood to connect the battery and check things out I noticed white dust all over every aluminum surface. I’m not sure what these deposits are? Truck fired up without any issue. I also noticed the exhaust pipe coming out of engine was all rusted. I have 2900 miles on the truck.
  2. Feb 19, 2018 at 10:24 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
  3. Feb 19, 2018 at 10:27 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s oxidation, like rust but on aluminum. It won’t hurt anything, it actually provides a hard layer of protection once it oxidizes and prevents any further corrosion.
    Mr-Paul and Pabloeeto like this.
  4. Feb 19, 2018 at 10:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Mineral corrosions/oxidation. Often salt related. At this stage it should clean up easily for you.
    Once I was shopping once for a specific vehicle, which happened to have lots of aluminum bits under hood. Every time I saw what you described (and worse, as in pitted and beyond cleanup) I knew it had been a northern car that had not had the engine bay cosmetically maintained.
    Which since it was a performance oriented vehicle, made me question other maintenance as well.
    Clean it up and you'll be fine.
    Mr-Paul likes this.
  5. Feb 19, 2018 at 11:24 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    eurowner likes this.
  6. Feb 19, 2018 at 3:16 PM
    JARStacoma
    Alaska
    Haha! Guess I would need snow first. Pretty week snow year up north. There’s grass in my yard!
  7. Feb 19, 2018 at 3:17 PM
    JARStacoma
    Alaska
    So do I need to clean this up?? Did it collect because it sat or because it just happens?
  8. Feb 19, 2018 at 3:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    salt coverage?
  9. Feb 19, 2018 at 3:26 PM
    tacoss
    tacoss Active Member
    2016 tacoma trd ord
    sea air . How close are you to the ocean?
  10. Feb 19, 2018 at 3:27 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Hose it off with the water hose...if it isn't frozen.
  11. Feb 19, 2018 at 3:53 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Its Al2O3, otherwise known as Aluminum(III)Oxide - as @crazysccrmd mentioned above, it will help prevent further corrosion on aluminum surfaces. Leave it if uou dont mind, otherwise clean and coat with something if it bothers you. Some environments will cause it to form faster than others (temp, moisture, salt, etc.)
  12. Feb 19, 2018 at 4:04 PM
    JARStacoma
    Alaska
    Thanks. I will leave it. I haven’t noticed it on my other vehicles but this is the first new vehicle I’ve owned. All others were acquired with 100,000 miles or more.
