White finish potentially ruined by "Frame Warranty Work"
Discussion in '1st Gen. Tacomas (1995-2004)' started by geoff06, Jun 22, 2011.
  1. Jun 22, 2011 at 9:54 AM
    geoff06
    geoff06 [OP] 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    So this morning my truck was in for frame "CRT" (corrosion resistant treatment) warranty work @ Wilde Toyota in Milwaukee. I gave it a once-over before I left the lot and I thought everything looked good. They warned me not to let the frame or suspension parts get wet for 4 days while the ooey gooey black goop cures. That alone will be tricky since it's been raining like every afternoon and I'm gonna need to do some driving in the next few days.
    My truck is white. original finish, and I've done a lot to keep it in good condition
    When I got home, I noticed a really bad looking black smear below the driver's side quarter window. I quickly got a wet paper towel to clean it off and guess what? Everywhere the paper towel touched instantly turned black and looked almost like a burn mark the size of my hand. OVERSPRAY!! :censored: Somewhat in shock, I looked really closely at the rest of the driver's side of the body, and to my amazement, the previously white finish looked grey upon close inspection. Then, since I was not sure of the extent of the overspray, I rubbed a small area of the quarter window and... oily looking, sticky smear. And on the windshield... oily smears according to where the "wind pattern" is. Good thing I didn't need to turn my wipers on!
    I immediately called the service dept. @ Wilde and told them what's going on. After talking to the service rep who worked with me, who at this point kinda started freaking out, he said I could bring the truck back tomorrow and they would "take care of it":mad:. Then he left a message on my phone a little while later and said that I could try fixing it on my own with lacquer thinner, if I don't want to bring my truck back to the dealer.
    I want them to fix what they screwed up. Is there some kinda compensation (like a complementary tank of gas) I can try to demand from the dealer for causing problems, and possibly causing improper setting for the CRT since it's supposed to rain tomorrow?
  2. Jun 22, 2011 at 4:03 PM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    See what they do to fix their mess up. Fully inspect the truck when you get it back BEFORE you leave the dealership. Maybe if you cause enough ruckus they might throw in a free oil change.:)
  3. Jun 22, 2011 at 4:06 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    If they fix it the first time, I wouldn't give them any trouble. If they refuse to fix or it still isn't fixed after you bring it in I'd raise hell.
  4. Jun 22, 2011 at 5:47 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    If they are going to strip it with lacquer thinner, make sure they wax it again. It will look dull soon if the remove the wax and not re wax the paint. I would expect them to detail the entire truck, and call it even.
  5. Jun 22, 2011 at 7:15 PM
    ERG80
    ERG80 Newb
    TN
    1997 T100 & 1996 FZJ80
    X2. They should clean the gunk, detail, and wax the outside at the very least.
  6. Jun 22, 2011 at 7:41 PM
    Big M
    Big M Well-Known Member
    Central Connecticut
    02 TRD xtra cab 3.4 5spd
    bilstein RCD 5100's all around, eibach coils, rear add a leaf, diff drop, cb drop, 33x12.5x15 tires, HID headlights, pioneer mp3 head unit, 12" sub with mono amp, grey wire mod, 2-low mod
    most dealerships have a detail center/department or at the least a detail shop they use to clean customer cars, trade-ins, and pre-delivery cars. They not only wash and wax cars but also deal with overspray removal. request your truck be taken care of by people who know and work with automotive finishes and not by the techs who will most likely just spray brake clean on a rag and wipe it off, along with your wax and dull your paint/ ruin your finish.....
  7. Jun 22, 2011 at 8:00 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I would have them remove the gunk and toss in a buff and wax.
  8. Jun 22, 2011 at 8:20 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    same thing happened to me. I just took it upon myself & washed the truck about 4 times back to back, and got ride of the overspray. Taking laquer to the paint dont sound like a good idea to me.
  9. Jun 23, 2011 at 11:41 AM
    geoff06
    WI
    thanks for the responses, guys. sounds like just about everyone is recommending what i have been thinking (they clean it, 'get rough' if they blow it this time).
    and that's a good point, Big M. i forgot that they usually have a seperate department
  10. Jun 25, 2011 at 8:40 AM
    geoff06
    WI
    Well, a couple more phone calls, one more trip to the dealer, 3 coats of wax, one destroyed microfiber cloth later and... my truck is pretty much back to normal. Someone from Toyota customer service called me yesterday afternoon to ask me about my dealings, and I told him about the overspray and I was honest about how angry I was. Haha, it also turns out that I was supposed to be offered some kinda complementary service (though now I can't remember what it was). Oh well whatever, at least my frame is officially warranted for a few more years.
    Now it's time to tap into the dash fusebox and finish installing my CB
