White gas vs propane stove for tailgate cooking
Discussion in 'Outdoors' started by Trucks2019, Apr 21, 2024.
  1. Apr 21, 2024 at 9:28 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    In the market for a new stove and thinking about white has instead of propane. Any who has switched from propane to white gas or vice versa able to provide some feedback?
    I’m looking primarily at either the Jetboil genesis halfgen or the MSR dragonfly.
  2. Apr 21, 2024 at 9:40 PM
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    I'm a fan of whitegas, but as a liquid fuel, you need to pressurize it, and there's no piezo built in to most whitgas stoves. But if you're truck camping... :shrug: I'd just roll with a propane 2 burner.
    ScrippsRanch67 likes this.
  3. Apr 22, 2024 at 9:13 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I’ve used both and like both. Being old school I’m a little partial to white gas. But now a days I’m 100% propane. The number one reason is that propane is way more available than white gas. You can find it anywhere and everywhere. Also easier to use, less hassle. You can either use the small disposable containers or you can go with a small couple gallon refillable tank. With a tank you are good for a week or more camping using it for cooking, lanterns, small gas grills etc. I’d go propane.
  4. Apr 22, 2024 at 10:11 AM
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    I primarily use these guys as a go to for camping/cooking accessories. Storage, travel containers, accessories.... and these are what Smartcaps new Kitchen model uses so its compatible if you have that system as well!
    https://gsioutdoors.com/?gad_source=1&gclid=EAIaIQobChMI7u392p3WhQMVXaJaBR3yFgx5EAAYASAAEgLYUPD_BwE
  5. Apr 22, 2024 at 10:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Propane is so much easier and convenient. The only real downside is using it at high altitude or extreme cold.
    gsubioguy likes this.
  6. Apr 22, 2024 at 10:35 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    The “disposable” thing bites. Convenience is going to end us.
    KactusJack and suomiM31 like this.
  7. Apr 22, 2024 at 10:57 AM
    Sprig
    Ken
    Yep, the sky is falling and the zombie apocalypse is about to begin all due to disposables.:nuclear:
    abou824 and davidstacoma like this.
  8. Apr 22, 2024 at 11:44 AM
    .劉煒
    There's coleman style propane cannisters that are refillable.
    essjay and bagleboy[QUOTED] like this.
  9. Apr 22, 2024 at 11:47 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The earth isn’t disposable nor is it replaceable but we can trash it to our hearts content so please go ahead and conflate science fiction with the reality.
    KactusJack, Thunderball and gsubioguy like this.
  10. Apr 22, 2024 at 11:51 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Been absolutly abusing a 2 burner coleman propane stove for years and it lights off everytime. Also you can refill the 1lbs bottles off of the larger propane tanks. Or get an adapter to run a larger tank on the stove. We get a few days of use out of the 1lbs cylinders.
  11. Apr 22, 2024 at 11:56 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    buddy you'd have to be really cold and/or high to get beyond propane's limits. with a -44 boiling point, at 10,000 feet you'd be good down to about -24f. at that point I hope you have taken other precautions to survive. you may be thinking of butane
    TacomaAddict23 likes this.
  12. Apr 22, 2024 at 12:07 PM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    I used a 2 burner homestrand alcohol stove when I traveled in my old van. Alcohol is pretty safe, but if you are trying to heat water, it takes quite a bit of time.
  13. Apr 22, 2024 at 12:09 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Not that it should ever happen in the hands of a responsible person, but I have seen people spill white gas in the most inconvenient of places.
    I have also seen people accidentally light the outside of their leaky gas bottles, more than once. Again, it shouldn't happen, but I've seen it happen.
    If you're putting your stove on the tailgate, I would 100% choose propane. You don't want uncontrolled oopsies in proximity of your truck.
    suomiM31, T Fades, SR-71A and 2 others like this.
  14. Apr 22, 2024 at 12:24 PM
    Sprig
    Ken
    :rofl::rofl::rofl::rofl::rofl:
  15. Apr 22, 2024 at 12:35 PM
    mlevimadden
    mlevimadden Well-Known Member
    Colorado
    13 DCSB TRD OR
    Propane is more convenient for truck camping, but I've had a couple backpacking white gas stoves. White gas will do better once the temperature drops below about 20F. I've had trouble with propane bottles freezing up once it gets that cold. Propane also struggles a bit more if you start getting above 10k ft of elevation, but there aren't too many roads higher than that.
    SR-71A likes this.
  16. Apr 22, 2024 at 12:40 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I like the idea of flexibility. A propane stove runs on propane only. Some of the gas stoves can use anything from gasoline to kerosene.
    If you should happen to run out mid-trip or forget to grab fuel before you roll out, a multi-fuel stove might give you more options.
    ricphoto likes this.
  17. Apr 22, 2024 at 5:33 PM
    .劉煒
    Different stoves for different uses. I have a whisperlite international that'll run on anything (primarily whitegas, though), and it's my mountaineering stove. For scout style camping, I run a single burner (not iso) butane Snow Peak Home and Camp. I like it for actual cooking a little more than the isobutane since it's wide and low and can support actual cooking pans with weight on top, and has an autoignighter. Then I have the biolite fire pit for wood burning and charcoal, a two burner for car camping ...
    Just about all of them have their place in the scale of 'what kind of thing do I want'. Heck, I don't have one but the little jetboils are nice for heating water quickly, too.
  18. Apr 22, 2024 at 5:41 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    I’ve been rocking a Coleman Dual fuel with gasoline for the past 5 years and it’s never missed a beat with freezing temps or altitude. Best of all, I can get fuel for it at any gas station :D
  19. Apr 22, 2024 at 5:51 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    A gallon of white gas lasts a LOOOOOOONG time and can be used for cooking or light. They [the stoves or lanterns] are also pretty cool to collect.
    chrslefty likes this.
  20. Apr 22, 2024 at 5:55 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    White gas and gasoline are dirty, they leave black soot on my pots and pans. But it's easy to pack a small MSR bottle and little pump stove so that's what I use when I backpack. Use a filtered funnel to keep flakes of crap out. But for car camping, I just bring a 20lb propane jug. I can hook the lantern and stove up and live like a king. I also bring a propane torch to light campfires. Grain alcohol also works great in a Coleman fuel stove, plus it will also get you hammered. Don't leave it in there because it will destroy rubber gaskets
