White Gunk in Oil Filler Cap/Tube
Discussion in 'Technical Chat' started by Lexirob, Feb 21, 2010.
  1. Feb 21, 2010 at 4:34 AM
    Lexirob
    Lexirob [OP] Member
    Rob
    Rhode Island
    08 Tacoma 4x4 Double Cab
    Step Bars
    When I did the first oil change I noticed white gunk on the underside of my oil filler cap and also at the top part of the oil filler tube. I figured it was possibly assembly lube that got slug up there by the timing chain. Now the truck has 21k miles and even though I've cleaned it off before, it actually seems to be accumulating. I check the oil frequently and never saw any red flags such as streaking in the oil from coolant, and my coolant level is holding strong. This is concerning me because on my most recent oil change last week I didn't pull the drain plug. I used one of the better devices to suck the oil out through the dipstick. The vacuum device worked well and got all the oil, but I saw a couple of pieces of sludge get sucked up the tube. I've always been a fanatic with maintenance and never exceed my oil change intervals. I do not haul, tow, or plow with the truck and it's never overheated. Could I be cooking my oil somehow? Please help. Thanks.
  2. Feb 21, 2010 at 4:41 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I think the white gunk in your cap is condensation mixed with oil causing it to turn that color. I have that on my cap also. The first time I saw it I was concerned but every time I drain the oil it looks good.
  3. Feb 21, 2010 at 5:10 AM
    red neck toy
    red neck toy Well-Known Member
    earle
    adams center, New York
    05 tacoma dbl lifted
    -3in toytech lift -33" x 11.5" firestone destination m/t -16" x 10" mickey thompson classic II. -cut and boxed in body mounts so no more rubbing!! -black headlight covers -anytime foglight mod -35%tint front -5% over stock on back -custom built bull bar -mossy oak camo seat covers -k&n cold air intake -tornado gas saver -dual straight pipes. only tacoma i've seen with them and it sounds really good. (but not if you dont like loud) lol.. soon to come: -black headlight mod -aftermarket grill -blacked out emblems -headers -new shocks and leafsprings - considering all pro front bumper
    yeah ive had it a couple times. its no big deal. ive heard it can happen from driveing only a couple miles every day.
  4. Feb 21, 2010 at 5:11 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Its condensation. Cold weather, the long plastic fill tube and short trips make it worse.
