White gunk in Oil filler tube
Discussion in 'Technical Chat' started by niit_train, Jan 28, 2010.
  1. Jan 28, 2010 at 1:37 PM
    niit_train
    niit_train [OP] Well-Known Member
    WV
    06 Double Cab
    No mods, just extra accessories. Realtree bug shield, vent visors, and a custom Realtree Hunter 4X4 Bully
    Okay, I tried searching thie topic, but found no threads on it, so here it goes:
    I was doing my 60000 mile maint. and started by changing the oil filter. After I did this, I removed the filler cap to allow air into the system for draining...just a habit. After removing the filler cap, I noticed a white gunk build up in the filler tube. I researched this at google, and found that it may be normal in cold temps on short trips. Has any 2nd generation folks experienced the same thing? It is a 4.0L and I beleive the filler tube is plastic, which would sort of explain it. The temps around here have been in the teens and twenties. Any insight is appreciated.
    NT
  2. Jan 28, 2010 at 1:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its condensation. Normal. Change your oil more frequently for better protection in cold weather/short drives.
  3. Jan 28, 2010 at 1:40 PM
    Bombero
    Bombero New Member
    Seatown
    06 Quad cab Sport
    None
    This happens when water gets mixed in with your oil. I think short trips can cause this. I'm not 100% sure but I think the remedy is more frequent oil changes. I use to get this a lot with my Ram prior to trading it in.
  4. Jan 28, 2010 at 1:56 PM
    niit_train
    WV
    06 Double Cab
    These are the answers I was hoping for. I still need to check the anitfreeze and tranny fluid to make sure.
    NT
  5. Jan 28, 2010 at 2:21 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    I noticed the white gunk for the first time last month when I changed my oil. I have only use mobile 1 and drive 8 miles one way to work and the temps have been in the teens. I figured it was just condendation like the others said.
  6. Jan 28, 2010 at 2:22 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Glad I read this. I saw the same thing last time I changed my oil.
  7. Jan 31, 2010 at 7:10 AM
    craggar1
    craggar1 New Member
    Craig
    Ontario,Canada
    Tacoma SR5
    PHEW!!! I just purchased my tacoma and I noticed that white gunk as well. It's a 2008 with only 10,000 miles on it so when I saw that, it worried me. Good to hear the condensation thing. My dipstick is clean and there was nothing on the visable timing chain under the cap.
