White gunk, under oil cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hitsy, Feb 13, 2016.
  1. Feb 13, 2016 at 2:52 PM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    Soo..changed my oil, im assuming i put on bout..6k miles on the last oil. But, there was this white gunk under the cap. Now. Smelled like motor oil. I run short trips to work, like..60 miles a week. (6 days lately). And i let it idle a min before i leave so its not up to temp just idles low. Its a 2007 2.7 4x4 blah blah, thinking just condensation cause i dont run long trips. Considering i burn dust when my heaters on lol...worst case..head gasket? Only 137k miles
  2. Feb 13, 2016 at 2:54 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    IIRC, this is common if you run short trips. Just water condensation. If you run their engines longer, the water will burn off.
    Nothing to worry about either way.
    Boone likes this.
  3. Feb 13, 2016 at 2:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yep, normal. Lots of short trips never burns off the moisture.
  4. Feb 13, 2016 at 2:56 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    this, cuz ya didnt mention that the oil looked like choco-milk, and that u are using/losing coolant
  5. Feb 13, 2016 at 3:10 PM
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    Glad you asked the question. After changing my oil today in my '14 at 38k miles, I noticed the same thing and it had me nervous.
  6. Feb 13, 2016 at 6:32 PM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    well yeah, not losing coolant, just a small concern, so i asked, thank ya'll btw.
  7. Feb 13, 2016 at 9:26 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Wow this has become a daily question.
    I think we need a sticky thread.
    Sig45 likes this.
  8. Feb 13, 2016 at 9:28 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Sticky for milky white gunk, interesting thought.
    QChawks[QUOTED] likes this.
  9. Feb 14, 2016 at 3:57 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    ^^ This ^^ I think this is the 403rd thread on this topic in 2016.
  10. Feb 14, 2016 at 4:46 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    well most people, don't really check forums for a specific problem, to many threads for that, easier to just ask, get a direct answer, thank yall
  11. Feb 14, 2016 at 5:14 AM
    Sig45
    Mark
    Maine
    There's a search button for a reason...just sayin'.
    QChawks likes this.
  12. Feb 14, 2016 at 5:17 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Help someone, get helped yourself, or get out of the way and quit whining.
    White goo under cap is normal, indicative of short drives and condensation not getting "steamed out" due to lack of sufficient heat.
    robm7 likes this.
  13. Feb 14, 2016 at 5:22 AM
    sull625
    sull625 Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    Also common when climate temp is cold
    oldracer likes this.
  14. Feb 14, 2016 at 5:37 AM
    oldracer
    oldracer Well-Known Member
    Yes the colder temps, accentuate the moisture problem.
    If you only drive short trips in the winter, (and of course if you live in a colder climate), you should change the oil and filter more frequently, in the winter.
    Speaking of that, I just looked my my thermometer, at the house, and it is 2 degrees BELOW zero right now.
    sull625[QUOTED] likes this.
