White Noise Question
Discussion in 'Audio & Video' started by eodrunner, Apr 16, 2013.
  1. Apr 16, 2013 at 3:23 AM
    eodrunner
    eodrunner [OP] Well-Known Member
    Jerron
    Guam
    10 PreRunner
    2 JL 10W3, Infinity reference series speakers all around, infinity 1600a and 475a amps, Pioneer Avicenna-z140bh
    So I've got a question about my system that I'm hoping someone can give me guidance on. Here's my setup. I have a Pioneer AVIC-Z140BH head unit, an Infinity 1600a and 475a amp, front and back infinity speakers and two 10w3 JL subs. Here's the problem I'm having.
    Inbetween songs you can hear a fair amount of white noise, and I can also hear a little engine noise when I accelerate. Has this happened to anyone and what did you do to fix it. One thing I'm thinking is maybe the RCA and speaker wires aren't thick enough. Does that sound like it could be a possibility to anyone? Thank you very much for any help given.
  2. Apr 16, 2013 at 5:18 AM
    fletch97
    fletch97 Professional Window Licker
    NJ
    2013 Tacoma SR5
    It could be several items but the ground wire would be the first thing to check. Check ground wire on head unit and amp, make sure it's a solid metal surface with no paint. Most noise interference I've seen was always caused by a bad ground. Obviously the next item to check is your cables, make sure they are well insulated, no cuts in them, etc.. There could be a bad wire/cable somewhere. Perhaps you can buy a few cables, run them outside the car temporarily and see if that solves the issue. (I would buy decent cables too, don't buy the cheap walmart crap!)
    I wish I could offer more help, but that's where I would start.
    Good Luck!
  3. Apr 16, 2013 at 2:21 PM
    pinktaco808
    pinktaco808 Hot Steppa
    hiss noise?
  4. Apr 17, 2013 at 9:24 AM
    Shaowei
    Shaowei Well-Known Member
    New Mexico
    05 Tacoma 4x4 LB
    Check your amp gain as well. I installed a new amp and had all kinds of white noise and was worried that my ground was bad. Long story short, I checked the gains on the amp and they were maxed out. Turned them down and it disappeared immediately. The ground was fine.
  5. Apr 17, 2013 at 2:32 PM
    Aw9d
    Aw9d That one guy
    Az
    Amp gain to high or bad ground and MAYBE bad RCA's. I've seen once where the RCA's that the customer brought in were just bad out of the box. Typically ground and gain causes 'hisssssss' noise. People think the gain on the amp is like a volume knob on the HU, its not the same.
  6. Apr 17, 2013 at 5:09 PM
    chetweewax
    chetweewax Well-Known Member
    NJ
    05 TRD Sport SR5
    Homelink mirror with back-up camera (like stock 09-11's), Kenwood stereo with factory steering wheel controls, Weather Tech Mats, Factory Bed Mat, Leer Cap, 2011 Waffle grill & smoke headlights, DEPO LED tail lights, NEW FRAME!!
    While I don't have an amp in my taco, I have had many over the years. Most of the time noise like you are describing is ground related, like others have said.
    One tip I could give you is up the size of the ground. If you are using 4 awg wire for power, use 2 awg for ground, make sure it is a separated from any other electronic grounds, and all paint is removed from the attaching surface.
  7. Apr 17, 2013 at 10:06 PM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    This is the picture I took of what the grounds from the amp looked like. I'm gonig to the store after work to get a legit bolt and grind the paint down to make a solid ground. I had gotten the work done at a shop here on island before everyone told me not to go to that shop. Ugh. If that doesn't work I'll order RCA cables and rerun everything. The ones that it has on it seem thin.
    Any suggestions on RCA cables to go with?
  8. Apr 17, 2013 at 10:54 PM
    pinktaco808
    clean it super good
  9. Apr 18, 2013 at 1:57 AM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    So I drilled in a new bold and grounded it, took off the paint, made it pretty, sorry no picture yet, and tested it, same thing. So then I looked at the amp after I did all that work and the gain was about 1/3 up. Well, I turned it all the way down and poof, it's gone. So, what I learned from this is that now I have a solid ground and always check the gain first.
    Thank you for all your help!!
  10. Apr 18, 2013 at 10:29 AM
    Aw9d
    Aw9d That one guy
    Az
    That pic of the ground you have is wow. Your screws have a coating so they aren't touching metal to metal.
    Take out a seat bolt or seatbelt bolt, sand down paint and use that. Don't use those screws into sheet metal.
  11. Apr 19, 2013 at 7:53 AM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    Agreed. The best bet is to use the nearest seat belt bolt. Sand down the bolt hole and use that. I had to adjust the gain to get rid of the white noise because the gain was maxed out. Right now I'm running around 1/3 or so gain without any background noise.
  12. Apr 19, 2013 at 7:53 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
  13. Apr 19, 2013 at 7:57 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    check all engine and vehicle grounds that are not related to the stereo
    check all plugs and wires and coils too...
    bad grounds can emit RFI and cause hiss/noise
  14. Apr 21, 2013 at 4:03 AM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    So the more I delve into the system I had installed in the truck, the more it looks like a 12 year old built it. And a very young twelve year old. The "custom" box the shop built is about half a cubic foot too small for both subs I have, the amp rack was pathetic and only used two screws per amp to hold my infinity amps in. All good components, but crappy work. So, I'm going to rebuild the box and move the amps under the seat. It'll probably take me a couple weeks to finish it since this will be the first one I've done, but I'll take pictures of the progress and see if I can't do a decent job with the plan I'm setting forth. So frustrating when you spend the money to get crappy craftsmanship.
  15. Jun 3, 2013 at 1:16 PM
    Cmyifyc87
    Cmyifyc87 Well-Known Member
    Md
    Tacoma 4x4 double cab
    6 in susp. Lift 3 in body lift, 20' XDs, exhaust, tbs, cai, jet MAF. uni-chip tuned with cai and exhaust. pending headers...
    you may want to make sure your component speaker wires are running near your power wire cable it can make a humming noise while you drive just an idea if you havent thought of that yet.
