White Rim Adventure with a Little Mud Thrown in for Good Measure
Discussion in 'Trip Reports' started by Digiratus, Nov 30, 2022.
  1. Nov 30, 2022 at 2:55 PM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    About a month ago a group of friends got together to run the White Rim road in Canyonlands NP. Present was me, @Speedytech7, @drr and his father Richard.
    Zane and I arrived on Sunday afternoon after a 2 day drive from Spokane.
    This is the Dome Plateau Overlook, our first camp spot of the trip. It used to have this amazing camping area right down near the cliff edge. Since I was there last (several years ago) the BLM has changed access so it is no longer possible to get down to the lower ledge area in a vehicle.
    Though not nearly as cool as it used to be, still great views from the higher up camp spot they created.
    That lighter colored area in the foreground of this VVV photograph is where we used to be able to camp.
    [​IMG]IMG_8788-Pano by Speedytech7, on Flickr
    edit: Added this photograph from Zane's Flickr album.
  2. Nov 30, 2022 at 3:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
  3. Nov 30, 2022 at 3:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The following morning, Dan and Richard showed up after driving 20 hour straight from Seattle.
    Richard took quite a large number of photographs (way more than me) that I will be posting throughout this report. These next four are ones he took the morning they showed up at Dome Plateau.
    The last time I was here, it was with @Blackdawg and @turbodb. This photograph shows the slab of rock they competed for to see who could setup their tent closest to the cliff edge. IIRC, they both ended up parking there rigs within inches of each other (and the edge).
    They wont be doing that again.
    Looking back from the cliff edge you can see where the BLM moved the camping area to. That white speck is Zane's truck.
  4. Nov 30, 2022 at 3:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Here's a few from our next campsite that wasn't very far from Dome Plateau. This one happened to overlook the backside of Arches NP.
  5. Nov 30, 2022 at 3:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
  6. Nov 30, 2022 at 3:54 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You know in all our adventures I'm amazed we still haven't found Carmen Sandiego.
    turbodb likes this.
  7. Nov 30, 2022 at 3:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The following day we took the scenic route into Moab with the plan to run some of the trails in the Sand Flats recreation area.
  8. Nov 30, 2022 at 4:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This time it was Fins & Things.
    After Dan did this obstacle, Zane and I were warned we might want to consider doing the left hand line instead of the center one.
    This must be one of the 'things'... :rofl:
    turbodb likes this.
  9. Nov 30, 2022 at 4:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    We had previously decided that we would run the White Rim road starting from Potash road on the Colorado River side. This meant an early start so we could reach our Potato Bottom campsite before sunset. This plan would also allow us to complete the road early enough the following day to have enough time to get down to the Needles district to camp.
  10. Nov 30, 2022 at 4:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
  11. Nov 30, 2022 at 4:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
  12. Nov 30, 2022 at 4:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Up to this point we had been blessed with some great weather. Like mid-60s during the day. But the weather was changing. We could see the storms coming in from the west as we turned north to head up the Green River side of the White Rim.
    SoCalSB, turbodb and Stuck Sucks like this.
  13. Nov 30, 2022 at 4:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The following day was a rainy one, with the hint of snow in the air.
    turbodb likes this.
  14. Nov 30, 2022 at 4:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
  15. Nov 30, 2022 at 4:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
  16. Nov 30, 2022 at 4:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    looks like a good time. Wish I could have gone. I have so much PTO now and no way to use it.
    Oh well.
    Can quite tell from the photo. Is the ledge gone or the path to it just collapsed on dome plateau?
  17. Nov 30, 2022 at 4:52 PM
    Speedytech7
    The ledge and path are there, but they have erected a barrier keeping you from starting on the path and they've added fallen branches and whatnot to make it not look like a road. I walked out there though, can still do that.
  18. Nov 30, 2022 at 4:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah. Bummer. Well was cool while it was.
    guess I need to edit those photos since it was cool then.
  19. Nov 30, 2022 at 5:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    When we finished the White Rim road, we headed south to the Needles District to a campsite we had found 18 months prior with our friend Ben @m3bassman Unfortunately the weather was getting worse. Cold and kind of dreary, just what one would expect on one of our adventures. :oops:
  20. Nov 30, 2022 at 5:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The campsite is a great desert campsite, tucked up in a canyon. Unfortunately is has one flaw which we had overlooked although the signs were all around us.
    We had setup camp and the storm that had been threatening all afternoon finally arrived. It started to rain so Dan deployed his new 270° awning for us to have some refuge. And it rained and rained and rained. It rained for several hours then it started to snow. I guess we were all ok with this but then we hear this new noise. It was the sound of rushing water.
    Yes, were were camped in a canyon that was also a desert wash. The water in the wash didn't turn out to be a huge deal as we had somehow avoided being parked in the very worst positions. Nonetheless, it was somewhat of a wake up call and a lesson learned.
    I don't have an photos of all of these events as it had gotten dark. Richard didn't either. Maybe Zane or Dan do.
    turbodb likes this.
