White smoke from exhaust pipe.
Discussion in '1st Gen. Tacomas (1995-2004)' started by knoagreen, Mar 16, 2015.
  1. Mar 16, 2015 at 4:39 PM
    knoagreen
    knoagreen [OP] Well-Known Member
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    So I got a white smoke problem. I first noticed it yesterday. When I first start my truck up white smoke billows out the tail pipe. Once it warms up it stops for a bit. If I am just driving on the highway no smoke. If I'm driving through town it tends to start smoke after I have been sitting at a stop light for a couple minutes. If I am sitting at a light it doesn't smoke until I accelerate, then when I take off, enough smoke comes out to smoke out an intersection. I'm thinking possible blown head gasket. There are no other symptoms, besides the smoke the truck runs fine, oil looks fine, fluid levels are fine. Any ideas? Or anyone had the same problem?
  2. Mar 16, 2015 at 4:40 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    White smoke is Anti-freeze.
    Blue smoke is oil.
  3. Mar 16, 2015 at 4:40 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Forgot to mention its a 99 3.4l with 155,000 miles. Also never overheated and the smoke does not have a sweet smell to it.
  4. Mar 16, 2015 at 5:47 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Just pulled the air intake hose off to get to the spark plugs and noticed a lot of oil in the throttle body. Guessing that's the problem. Recently changed the valve cover gaskets and had to remove the throttle body to do so, but reused the throttle body gasket. So I'm thinking I may need to put a new throttle body gasket on it. Thoughts anyone?
  5. Mar 16, 2015 at 6:14 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Bunch of oil in the line going from the PCV valve to the throttle body. When I did the valve covers I changed the PCV valve, with one from the parts store. Guess I should have went to the dealer for and OEM one.
  6. Mar 16, 2015 at 6:35 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Keep an eye on the radiator fluid level. You MAY have a leaking head gasket or worse a cracked head. The only way to verify is to pull the plugs and look for a really clean plug or with one with caked on white deposits. If you find neither, it could be condensation build up in the exhaust. You could always do a compression and/or leak down test on each cylinder.
  7. Mar 17, 2015 at 7:59 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you will get oil from the PCV to the TB, the pressure forces out some and then it gets moved to the combustion chamber to get burned. now if you're talking a stream and not just "wet" then you have another issue.
  8. Mar 17, 2015 at 9:22 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    You should be able to smell either burning oil or the sweet smell of anti freeze. Have another sniff.
    The plugs should tell you something as well, oil burning will foul them with black crud.
    Don
  9. Mar 17, 2015 at 11:11 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    do a compression test, if you have ring blowby it adds pressure to the crankcase forcing airflow to increase carrying oil through the pcv into the TB.
    sorry to say but it 100% sounds like engine rebuild time to me, but you could just keep driving it like it is.
    pull all plugs and test compression on all cylinders one at a time, engine wear determines the pressures you get but good is around 150 psi but it can be as high as 175 psi or as low as 100 psi but whatever it reads, they should all be within 5-10 psi of each other.
    then squirt oil in one and recheck then do the others one at a time and record the increase in compression from a good squirt or two of oil in each cylinder (just enough to coat the rings with oil).
    if compression stays about the same, those rings are ok and if the cylinder has low compression its most likely do to the valves.
  10. Mar 17, 2015 at 6:36 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Yeah I'm talking like a large amount of oil in the throttle body, not just wet, but like its puddling up in there. Seems like it's coming from the PCV valve.
  11. Mar 17, 2015 at 7:47 PM
    keakar
    karl
    louisiana
    for now, doing the oil catch can mod will help with the smoke and oil puddling issues
  12. Mar 18, 2015 at 12:55 PM
    CD20H
    Ben
    North Texas
    The PCV is to remove crankcase pressure caused by piston ring blowby and to cause a vacuum in the crank case that assists keeping the oil in the engine by pulling it away from the seals. Want to see a mess? Remove that PCV and seal the crankcase. Every seal will be seeping oil.
    If you have that much oil in the intake......You need to do a compression check.
  13. Mar 18, 2015 at 5:13 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Ok doing a compression test right now ill post some results when I'm finished.
  14. Mar 18, 2015 at 6:38 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    So I did a compression test and all cylinders are at about 175psi + or - 5psi. So would that suggest its and issue with the valves then?
  15. Mar 18, 2015 at 6:55 PM
    CD20H
    Ben
    North Texas
    You have great compression numbers.
    Hmm.
  16. Mar 18, 2015 at 9:27 PM
    keakar
    karl
    louisiana
    with those compression numbers it means the rings and valves are definitely sealing well so that's great news.
    this means there is no reason you should be getting oil through the pcv valve and hose since low compression would be an indicator of blowby which you don't have based on those numbers.
    for now cleaning the TB and intakes manifold and doing the catch can mod will cure your smoke issues but unless this is old buildup over time that just finally got sucked into the TB (and maybe even reached its way all the way through the intake to the valves) there is nothing I can think of as a reason for your symptoms.
    those numbers are great news and signal there is nothing wrong with your engines rings or valves sealing.
  17. Mar 18, 2015 at 9:50 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The next thing to check is to do a pressure test on the radiator to test for coolant system leaks.
  18. Mar 19, 2015 at 10:53 AM
    keakar
    karl
    louisiana
    he already confirmed that the coolant levels are not changing
  19. Mar 19, 2015 at 9:37 PM
    knoagreen
    Willie
    Las Vegas
    2013 AC 4X4 OR MGM
    Well I tried a OEM PCV valve today. Drove it 10 miles, it still smoked occasionally. Pulled the air intake off and once again a ton of oil in the throttle body. I really don't under stand where else to oil could be coming from other than the PCV line. I guess I can try the oil catch can next, but judging from the amount of oil I'm seeing in the throttle body, the catch can will be full every few hundred miles.
  20. Mar 20, 2015 at 4:40 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    You sure it's oil and not steering or brake fluid?
