White Smoke on Start Up from Exhaust?
Discussion in '1st Gen. Tacomas (1995-2004)' started by choughton, Jul 26, 2020.
  1. Jul 29, 2020 at 11:52 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Make sure your coolant system is totally full. Mark either the cold or hot level, or both. Keep a eye on the level for a while, if it is coolant you will loose some over time. The pressure test is not fool proof by any means.
    cruiserguy likes this.
  2. Jul 29, 2020 at 12:01 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Describe the color of the smoke you see during start up !!!!
    Is it blue ????? , This is referred to as oil smoke and during start up this is caused by leaking valve guides or valve seals . Oil drips from either of these and puddles onto of the piston . It is quickly burned off during start up with visible oil smoke out the exhaust
    If the smoke resembles a steam cloud that doesn't dissipate and has sweet smell /aroma and you also notice water loss in your radiator or running warm you have an internal water leak
    This can be from either a failed head gasket , cracked block or cracked cyl head
  3. Jul 29, 2020 at 1:09 PM
    1997tacomav6
    Denver
    My engine did the same thing, it will get worse. If I remember I ran my motor for a good month this way and gave me time to find an engine just because my motor was high mileage,
    If you’re losing ANY antifreeze and have white smoke you have a head gasket issue.
  4. Jul 29, 2020 at 2:04 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Just a thought, is it an automatic or manual transmission? I have seen where in a auto trans the vacuum modulator diaphragm leaks and the vacuum line sucks the trans fluid into the engine.
    My .02
    US Marine likes this.
  5. Jul 29, 2020 at 6:13 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    what did they presure test ????????
    cooling system can be pressure tested
    not familiar with pressure testing a block or head
