White Smoke on Startup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by motorick, Feb 27, 2017.
  1. Feb 27, 2017 at 5:42 PM
    motorick
    motorick [OP] Jacksonville, Oregon
    Rick
    '16 Silver Tacoma TRD Sport DCLB
    Did a search and didn't find info on this... when 1st starting up my truck, I get 3 to 5 seconds of white smoke. Hoping this is normal and maybe condensation? My truck has 5k miles and today I started in here in Nor Cal around 58 degree F.
  2. Feb 27, 2017 at 5:46 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    For your area with that temperature, it's very normal.
  3. Feb 27, 2017 at 5:49 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Mine does it, my buddies does it. Cooler Temps with condensation, plus the injection cleaning process it does during start up all contribute to the white fog.
  4. Feb 27, 2017 at 6:06 PM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Im in Norcal. Mine does it. Its normal.
  5. Feb 27, 2017 at 7:37 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Cold will cause the gasoline to condense, causing a more rich mixture when firing. That's why you get terrible mileage in the winter. Everyone rolls coal, white coal
  6. Feb 27, 2017 at 7:45 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    As long as it's not bluish white, you're fine. That's usually higher mileage vehicles with worn valve seals letting some oil past and coming out the tail pipe before the cat is hot enough to burn it off.
    Totally normal for you to see early on cold mornings. Mine does it too.
  7. Feb 27, 2017 at 7:46 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I think you have a head gasket leak!
  8. Feb 27, 2017 at 10:15 PM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    It means your truck has chosen a new pope.... Honestly no clue, but it was too easy
    over60, LTacoman, Razgriz and 4 others like this.
  9. Feb 27, 2017 at 10:25 PM
    G-Dawgg
    G-Dawgg Well-Known Member
    Torrance, California
    '17 DCSB Super White TRD OR 4X4
    Noticed mines this morning as well. Very very brief though. Im in So Cal and it was about 60*F.
  10. Feb 28, 2017 at 1:01 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    It's a write off. I'll give you tree fiddy for it.
    GPsevinSixx likes this.
  11. Feb 28, 2017 at 1:03 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Sounds like you blew a head gasket. Not sure if your warranty will cover that.
    over60, GPsevinSixx and specter208 like this.
  12. Feb 28, 2017 at 1:29 AM
    NorthCoast4XN
    NorthCoast4XN Active Member
    17 TRD DCSB SPORT / 16 4RUNNER LIMITED
    Stock
    My truck does the same thing. Totally normal........Pacific Grove = Nor Cal ?
  13. Feb 28, 2017 at 2:25 AM
    Michal006
    Michal006 Well-Known Member
    PA
    2016 Tacoma TRD Sport 4x4 6MT
    :rofl:
  14. Feb 28, 2017 at 2:26 AM
    specter208
    California
    Head gasket, a lot money your burning! :D
    over60 likes this.
  15. Feb 28, 2017 at 3:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Light white, short term, cooler weather, condensation. Or coolant. There should be dripping from the tailpipe, a simple taste test will tell what it is.
    Too rich is black.
    Oil is blue.
    BTW, every other gasoline vehicle does this too, not just your truck.
  16. Feb 28, 2017 at 6:34 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Had a newer F-150 before. If i started it up when its under 60 degrees, it would do this. Kinda like breathing into cold air.
  17. Feb 28, 2017 at 7:00 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Not sure how much experience you all have with exhaust condensation, but it doesn't usually only last 3-5 seconds immediately after startup. That's usually oil in the cylinder burning off from leaking rings, valve stems, head gasket, etc.
    over60 and Kilokato like this.
  18. Feb 28, 2017 at 7:29 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    You noticed mines? You should really call that in to EOD.
  19. Feb 28, 2017 at 7:36 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    it's vaping
    over60 and Caligula like this.
  20. Feb 28, 2017 at 7:41 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    taste it
    if it tastes like snozberries it's head gasket
    Caligula likes this.
