White Smoke = Valve Guide Seals?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DBWrecks, Apr 19, 2013.
  1. Apr 19, 2013 at 5:49 AM
    DBWrecks
    DBWrecks [OP] Active Member
    Alex
    Indiana
    1995 Tacoma Xtra Cab
    I have a 1995 Tacoma XtraCab 4x4 automatic transmission with 227,500 miles. When I start the vehicle it tries to die, I then give it gas and it gets to it's regular sound/revving. However, for approximately 20-30 seconds white smoke comes out of the exhaust pipe. The interior of the cab smells of gas/oil when this happens. The more I hit the gas during this timeframe, the more smoke comes out.
    I have asked a few maintenance guys where I work what they think this is and they have lead me to believe it's the "Valve Guide Seals" that are leaking. They think it's allowing a small amount of oil that's being burned off each time I start it.
    Has anyone else had this problem? Does anyone else think that's my problem?
    Thanks for your help!
  2. Apr 19, 2013 at 9:33 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    don't know about the Tacoma, but in the vehicles i've had with bad valve guide seals, i get a blue smoke for a short amount of time on startup. usually don't worry about this, i just keep an eye on oil consumption.
    also it depends on what the 'white spoke' looks like. on cold mornings my vehicle has the white water vapor cloud coming out of the tailpipe, til the engine warms up a bit.
  3. Apr 19, 2013 at 4:24 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Check your air intact tube for oil. Pull it off where it conencts to the throttle body and look in with a flashlight/look at the throttle body. Is there engine oil there?
    If so, replace PCV valve with an OEM Toyota one (Don't buy a cheap-o generic, OEM is only a few dollars more and is built way better.). Clean the hose, and the intake out, get a new air filter if it's soaked and keep an eye on it. gdlk.
  4. Apr 20, 2013 at 8:50 PM
    shift96
    shift96 Well-Known Member
    White smoke is coolant. Check your head gasket
  5. Apr 20, 2013 at 8:57 PM
    Q Source
    Q Source Well-Known Member
    California
    04 PreRunner
    Supercharged, TRD Headers, URD 7th/SHORTIE 800cc injector, Snow Performance Water/Meth Kit, Deaver FJ59, Icon UCA, Fox Extended Travel Remote Resi, TG Front and Rear Bumpers, Deckplate Mod
    X2
    Check your oil fill cap if there is a white goo you've got a blown head gasket.
  6. Apr 21, 2013 at 5:47 AM
    Hansel
    Glenn
    Arizona
    base
    x3
  7. May 1, 2013 at 6:39 PM
    DBWrecks
    Alex
    Indiana
    It was the vaulve guide seals...I just bought this truck a few weeks ago and I have to replace the value guide seals, head gasket cover, motor mounts, front wheel bearing, 2 rear shocks, ignition, and a piece has to be welded that has come loose.
    $1300 with labor kinda sucks
  8. May 1, 2013 at 8:37 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I bet it will run like a top when it's all fixed though!
  9. May 1, 2013 at 9:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    My old boss has a Camry that smokes like Tommy Chong.
