White smoke??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CostcoTaco17, May 5, 2017.
  1. May 5, 2017 at 2:22 PM
    CostcoTaco17
    CostcoTaco17 [OP] Well-Known Member
    David
    San Diego, CA
    '17 Tacoma TRD OR DC
    OEM all weather mats, predator tube steps, TRD CAI, OEM rubber bed mat, derp
    So I just went to turn my my truck on walked around the back and saw white smoke coming heavily from my exhaust pipe. I'm at 3020 miles on my new truck and haven't done an oil change. Am I burning oil because I haven't changed it yet or has anyone else had this happen before? Can I wait till 5k to change it or should I do it now? It was cold this morning and I was blasting the heater as well
  2. May 5, 2017 at 2:23 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It's just condensation most likely. Not actual smoke.
  3. May 5, 2017 at 2:24 PM
    be_unscared
    be_unscared Wardaddy
    Brendan
    So Cal
    2016 TRD Sport 4X4
    My first question was temperature. Shouldn't be an issue with oil change. See if it's a constant problem and how long it remains white. If not, it's normal here and there and usually is just condensation.
  4. May 5, 2017 at 2:28 PM
    CostcoTaco17
    David
    San Diego, CA
    Update the smoke went away after driving 10 minutes. Their was a lot of condensation today and I'm less than 2 blocks from the ocean this morning. I'll check back later when I start "Bruce" up again. Still curious when I should do an oil change on a new truck
  5. May 5, 2017 at 2:30 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    When I bought mine brand-new they said change the oil as per the regular interval. They told me no special first oil change was necessary
  6. May 5, 2017 at 2:31 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    just condensation in the morning. no different than when you see your breath. as for going 5k for an oil change, that shouldn't be a problem since you're not due for one until 10k.
  7. May 5, 2017 at 2:31 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Simple rule of thumb...smoke doesn't dissipate that quickly, condensation will.
  8. May 5, 2017 at 2:37 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Mine usually takes a smoke in the morning after we have sex, but then it clears out.
    But if it smelled like coolant, or anything strange, then I'd be heavily drinking tequila!
    Cheers!
    jamestown likes this.
  9. May 5, 2017 at 2:38 PM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    The fuck....
  10. May 5, 2017 at 2:38 PM
    The hammer
  11. May 5, 2017 at 2:40 PM
    smitty99
    Scottsdale
    lynyrd3, uurx and 2016_dbag[QUOTED] like this.
  12. May 5, 2017 at 2:41 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Cool morning too, right?
    BLUE smoke is oil. White smoke that doesn't go away is coolant. White "smoke" that goes away is just condensation.
    Remember, one of the major products of burning gasoline is water vapor.
    BlueFalconActual likes this.
  13. May 5, 2017 at 2:41 PM
    Taco16LB
    Taco16LB Well-Known Member
    Blue smoke = burning oil. I had a Dodge that had a TSB for white smoke at start up . It had a bad gasket for the intake manifold .
  14. May 5, 2017 at 2:42 PM
    smitty99
    Scottsdale
    this
  15. May 5, 2017 at 2:48 PM
    The hammer
    You see how helpful ppl in this forum are OP, you asked about the white smoke, now it turns out there's other color smokes too. I guess it depends on what you're smoking as to the color?? :confused::confused:
    I'll just stick to tequila for today, but that's just me!
    happy Cinco de Mayo!
    Cheers!
    lynyrd3 and Taco16LB like this.
  16. May 5, 2017 at 3:04 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Check it while at operating temperature if you are still concerned.
    Recommending oil changes is a tough challenge. Toyota says 16,000km / 10,000miles. Many will accuse you of throwing money away if you do anything sooner. Now I changed mine at 1200km and this is my reasoning: Your motor will create more wear particles that end up in the oil in the first oil change interval than they will create in the rest of its life. At the LEAST I would suggest changing the filter early. I figured do both because at $60 or so at the dealer I can afford to.
    We used to build motors and run them until operating temperature then shut them down. Let them fully cool and do this again at least twice. Third time we would run the motor to 60% of redline and add 5% each lap until 90%. Once again cool off to full cold. Next time we would go to full redline and as soon as we hit redline we backed off to 60% and then redline or as high as we could for 15 laps or approx 30 minutes. Come in and change the oil. After that abuse it to full potential. The theory behind our break-in procedure is this - The initial heat cycles ensure everything is bedding in and expanding slowly. Any issues that show up now can be dealt with quickly. After the second heat cycle things should be mated or show issues. Then when increasing revs and allowing them to drop any particles that end up in the oil can reach the filter before being welded to something you don't want it to attach to. So adding force to the rings and mating surfaces forces them to wear and then the coasting allows oil to flush the wear particles away. By changing the oil at this point there is no question as to the capability of the filter to capture any additional wear particles. IT HAS NOTHING TO DO WITH THE CONDITION OF THE OIL. The oil should be fine but changing it ensures any particles still in the sump are flushed out instead of waiting for them to get caught in the filter.
    I don't fault anyone for doing their oil changes to Toyota specs. But as an industrial mechanic millwright my professional opinion of synthetics is they can either extend the life of your engine or lengthen the oil change intervals for a cost savings. Pick any one. You can't have longer life and longer change intervals. So I personally pick longer engine life and will do my oil changes early but that is my cost and my choice. So listen to whatever anyone else says and make the decision that works for you. If you are keeping the truck for 5 years or less do longer changes for a cost savings. If you are keeping it for a very long time then you could do Toyota recommended intervals or choose to do it sooner. It is all up to you.
    Lakeboy and Taco16LB like this.
  17. May 5, 2017 at 3:30 PM
    smitty99
    Scottsdale
    TLDR; just follow the owners manual and you're covered OP
  18. May 5, 2017 at 3:31 PM
    jgw
    jgw Yapping for over six decades
    Joe
    Western Montana
    2017 Tacoma Double Cab 4X4 TRD Off Road Quicksand
    Ultra flex tonneau, bed mat, Ionic nerf bars, weathertech mud flaps and floor mats
    New Pope.
  19. May 5, 2017 at 3:39 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :laugh:
  20. May 5, 2017 at 3:53 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Sounds like you already are drinking tequila?
    smitty99 and The hammer[QUOTED] like this.
