White smoke
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Jul 16, 2021.
  1. Jul 16, 2021 at 4:28 AM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Good morning everyone I'm having a bad one I tried starting my truck this morning and it was having trouble starting so I pushed the gas to help it a little and it started but really rough shaking and thick white smoke came out the tailpipe and i turned it off . Well I tried again and it started up fine this time but now there constant white smoke coming out the tailpipe what do you guys think it is the head gasket? And also I have my other truck but when I start it up it accelerates to 2000rpm and stays like that for a couple minutes then goes to 1200 and stays there and it also shakes a little when it's on idle. ( 2003 Tacoma V6 automatic and 2004 Tacoma V6 automatic )
  2. Jul 16, 2021 at 4:29 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    Should I drive my other truck since it has the idle and acceleration problems? I don't want both my trucks down
  3. Jul 16, 2021 at 4:33 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Check the coolant level, that will be the first indicator of a head gasket issue :thumbsup:
    Check your oil also, if it's milky that's another indicator.
    ToyoTaco25 and DES2009 like this.
  4. Jul 16, 2021 at 4:43 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    I did notice my Coolant level was low a couple days ago and I added some so I think I might have a leak and I just checked the oil it's normal. should I driving my other truck instead it accelerates on startup to 2000rpm but it goes down after a couple minutes
    six5crèéd[QUOTED] likes this.
  5. Jul 16, 2021 at 4:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If it were me, I'd drive the other one until you figure this one out. No sense in causing more damage if it is a head gasket.
  6. Jul 16, 2021 at 4:58 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Coolant system Pressure tester is your friend most auto parts rent them.
    I could not live without one.
    Your not smelling any coolant??
    White Smoke like a smoke screen ?
  7. Jul 16, 2021 at 5:01 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    Sometimes the head gasket will blow at an exhaust port. When this happens the water will leak into the exhaust system and not the oil. White smoke is antifreeze and water burning and blowing out.
    NSDON likes this.
  8. Jul 17, 2021 at 3:50 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    You can smell antifreeze in the exhaust smoke and likely see it looking really wet at the exhaust tip. I had a leak in the head in an old V8 on an exhaust valve, it just steamed out the exhaust and that cylinder had a miss from the antifreeze in the fuel in the cylinder. No antifreeze in the oil.
    A new head and gasket and all was good without any other damage. The car took a while to clear the antifreeze out of the exhaust after the fix.
  9. Jul 18, 2021 at 1:42 PM
    YotainOregon
    YotainOregon Well-Known Member
    Oregon
    1st gen Tacoma TrD
    Hope it’s not a cracked head man.
