White Stallion Suspenion Help
Discussion in '2nd Gen. Builds (2005-2015)' started by PrerunnerChris, Feb 18, 2010.
  1. Feb 18, 2010 at 11:02 PM
    PrerunnerChris
    PrerunnerChris [OP] Go Big Or Go Home!
    SoCal
    06 PreRunner V6
    I have a 2006 acc cab v6 prerunner with no trd or tsb on the back.i have talked and read from many people different things about the suspention that i want to run:confused:. So i thought maybe you guys could help me out i just got my 5100 billies the other day thanks to Downsouth Motorsports :D and now am about to order everything i need from toytec which includes my eibach springs and 1/4th inch spacer for the tacoma lean but i have also heard that i need to relocate the sway bars it this true:confused:? My last question is if i decided to set my billies to .85 then put the spring on which ill give me about a 2.5 inch of a lift would i need to get new UCAs? The reason why i ask this is because some people say tha they have set the billies to 2.5 and were able to get the alignment back to spec but i find that hard to believe:eek:. So if u guys think i need new UCAs then im not going to set them at .85 cause i dont have the funds for new UCAs right now:(. I would really appricate the help - Thanks:cool:
  2. Feb 18, 2010 at 11:21 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    At 2.5" I wouldnt bother with UCAs. I ran 3" without them and got a set since it was never quite within factory spec but I really cant notice much difference between having them and not having them on.
  3. Feb 19, 2010 at 7:00 AM
    PrerunnerChris
    SoCal
    06 PreRunner V6
    Thanks bro and do u know anything about the sway away bar ? if i need to relocate them or not ?
  4. Feb 19, 2010 at 7:07 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Relocation of the sway bar is very easy.... remove 4 bolts, install spacer/relocation plate (4 bolts), install sway bar bracket (4 bolts).... very easy and will keep sway bar from hitting your new shocks.
  5. Feb 19, 2010 at 7:10 AM
    PrerunnerChris
    SoCal
    06 PreRunner V6
    k thanks sounds easy to me:D and just a question but what do u think about me geting the new UCAs do u think them if i get about a 2.5 lift ?
  6. Feb 19, 2010 at 7:15 AM
    HBMurphy
    Paul
    So California Coast
    None
    See what happens. My opinon... If you can get the setup to run straight with no bumpsteer, wear etc - If you can afford them right now. Take that money and buy 5 shares of TM (Toyota Motor). Then wait for as long as you can. Prefreably after the TM has gone up in value $10 per share. :D
    Just my opinion... Kinda like asking a carpenter what you should build your home out of...
    Good luck and post some pics!!!
  7. Feb 19, 2010 at 7:24 AM
    PrerunnerChris
    SoCal
    06 PreRunner V6
    haha aight thanks bro and yeah ill forsure post pics when im done :D
  8. Feb 23, 2010 at 1:14 PM
    PrerunnerChris
    SoCal
    06 PreRunner V6
    i got one more question would i be able to put on the eibach springs myself if i had a spring compressor?
