White sweet smelling smoke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickSanchez, Jun 19, 2017.
  1. Jun 19, 2017 at 10:44 AM
    RickSanchez
    RickSanchez [OP] Well-Known Member
    Kris
    Bozeman, MT
    2010 TRD OR DCSB
    Keeping it pretty stock w/ creature comforts to come in the future.
    LOL, ok man, I'll let you know.
  2. Jun 19, 2017 at 10:57 AM
    evilcorvette
    evilcorvette Well-Known Member
    oderus urungus
    Syracuse NY
    Generally a water jacket passage that's leaking into a combustion chamber is VERY noticeable. It looks like a car smokescreen from a James bond movie. Its heavy, white, cotton ball thick smoke.
    If your coolant level isn't changing and there isn't any muck in your radiator or overflow tank, I think you just have a case of the new car jitters. (Muck being copper colored or silver colored flakes or brown syrup, this is what most snake oils look like in your system)
    RickSanchez[OP] likes this.
  3. Jun 19, 2017 at 12:32 PM
    MilSpec
    MilSpec Well-Known Member
    2014 Tacoma TRD Off-Road [1GR-FE] [A750F]
    Ditto. The white/sweet smoke is a telltale sign of coolant leaking into the engine. You can usually tell if there are perpetual bubbles in the radiator as well, and if there is a frothy, foamy head in the oil.
    I have had this happen twice before as a result of a bad thermostat causing the engine to overheat. It was just enough to warp the head and make the gasket leak. Needless to say, I swap thermostats every time I change my coolant nowadays.
    Sorry to hear.
  4. Jun 21, 2017 at 11:12 AM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    Borrow a block compression test kit from your local auto parts store like OReilly or Autozone. You have to purchase a bottle of test fluid for around $8. You drain some coolant to make headspace in the radiator, then use the kit to draw air from the radiator headspace through the test liquid. No color change means headgasket is not leaking into the combustion chamber. Kit is very sensitive and will detect a leak before you will see bubbles in the radiator. Some shops do a similar test with a multi gas meter. Basic concept is the cylinder pressure is higher than the radiator which runs around 15lbs, so if the gasket is blown, combustion gas will be forced into the coolant and is detected in the radiator headspace....same thing that causes the bubbles.
    Edit: You have to start with a cool engine so you can remove radiator cap, so run it long enough to open the thermostat.
  5. Jun 21, 2017 at 11:13 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    there is nothing quite like the sweet smell of white smoke
    BassAckwards likes this.
  6. Jun 21, 2017 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    White smoke from exhaust, excluding the early morning condensation vapors, is easy to determine the difference between two notoriously infamous smokes.
    Coolant smoke whisps away. Or evaporates off quickly.
    Oil smoke lingers for quite a while before dispersing, and can also be in thick clouds. I.E. Smoke screen.
  7. Jun 21, 2017 at 12:23 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    As long as you dont find this......
    Torspd likes this.
  8. Jun 21, 2017 at 4:56 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    My last 4Runner would do this every once in awhile,but the coolant level would slowly drop. Ended up being the radiator tank had the slightest leak.
  9. Jun 21, 2017 at 5:20 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    How do you know what ass taste like?
    phillstill and igno1tus like this.
  10. Jun 21, 2017 at 7:02 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    White, 'sweet' smelling smoke? In the old days, we used to make it a point to have a bag of Doritos on hand...
  11. Jun 21, 2017 at 7:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Freshly showered, or out of the pool wouldn't taste nearly as bad as coolant saturated exhaust. Vehicles' equivalent to swamp ass.
