white wheels that fit ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FuzzHead, May 29, 2011.
  1. May 29, 2011 at 7:00 PM
    FuzzHead
    FuzzHead [OP] Member
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    Bilstein 5100 all around set @ 1.75; smoked OEM fog lights; smoked Wade hood protector; OEM large storage box; cruise control; OEM intermittent wipers; 304 double-walled stainless exhaust tip; Sirius StarMate with FM direct adapter; front mud flaps removed; Minnesota Wild license plate holder
    My mind is made up. I want WHITE steelies for my super-white tacoma. Does anyone know of any 16x7 or 16x8 that will fit without hitting the caliper?
    I was looking at getting the Pro-Comp 82 series 8 spoke. They have 4 inches of backspace. I tried to call Pro-Comp but didn't get any help. Does anyone here have these?
    I would really like to stay with 16" but would consider 17" if I absolutely had to. I prefer to keep the cost under $100 per wheel. Also, am I better with a 7" or 8" width? I plan on running BFG TKO 265/75/16.
    Thanks in advance for any replies.
  2. May 29, 2011 at 7:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    4.0 might is close to too little backspacing. Some report rubbing on the outside of the sidewall because the tires stick out too far, but others have run those specs with no issues. I would ask if you can test fit them.
    Also kudos for being different with the wheels selection
  3. May 29, 2011 at 7:28 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Do you have the stock steelies?, if so just paint them. I like the stock wheels painted.
  4. May 29, 2011 at 8:05 PM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    i've considered painting my stock steelies, but they all ready have rust on them and i don't have a 2nd car, so it would have to be something i could do myself in a weekend. just seemed easier to get new ones. maybe i could sand the hell out of them and just spray prime, paint, and clear on them?
  5. May 30, 2011 at 6:49 AM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
  6. May 30, 2011 at 6:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    I don't know how extensive the rust is...But if you have a set of jack stands you should be able to have all 4 wheels done in one day.
    I did my stock wheels with just 2 jackstands in a weekend. Took the front 2 off- Cleaned, roughed up, cleaned again, primer 3 times and paint 3 or 4 times, cured over night in the house, and re-installed. Repeat with the rear wheels.
  7. May 30, 2011 at 9:43 AM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    I found a set of Cragar Nomad I online. Do you think these would have a chance? 16x7, 6x5.5 bolt pattern, 4.5" of backspacing. found on summit racing's site.
  8. May 30, 2011 at 9:49 AM
    KPT
    09 Prerunner
    Those are perfect specs, as long as they will clear the calipers. Some 16s won't
  9. May 30, 2011 at 9:51 AM
    KEG'sTACO
    KEG'sTACO FJ Cruiser
    Kurt
    Auburn, AL
    '08 FJ Cruiser
    Leveled, 33" BFG A/Ts, Demello Offroad front flat-top bumper, Demello Offroad rear 3-piece bumper, 17" Liquid Metal Gatlins, Pioneer audio upgrade, custom mounted 10" subwoofer, offroad interior
    I was going to run white steelies, but settled for the wheels I have now. good luck on your search! can't wait to see them on the truck.
  10. May 30, 2011 at 10:02 AM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    the Cragar also state that they have +12mm offset. i believe the stock wheels are +15mm (correct me if i'm wrong) so that would be pretty darn close. I think i may call and ask if they will let me test fit although i would probably have to eat the shipping 1 way.
    I really considered painting my stock ones but i live in an area that puts a LOT of salt on the roads in the winter and although i could powdercoat my stock wheels it wouldn't be much more expensive just to buy new at $80 a wheel. I also like the old school 8 spoke style a little more than my 5 spoke stock.
    thanks for all the replies. i just joined this forum yesterday and i am loving all the mods i see.
  11. May 30, 2011 at 10:09 AM
    KPT
    09 Prerunner
    Stock wheels are +38mm offset, which is 5.5" backspacing on a 7" wide wheel.
    +12mm offset on a 7" wide wheel is 4.5" backspacing.
  12. May 30, 2011 at 10:13 AM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    perhaps my search is not over. maybe i'll have to go for a 16x8 with 5.5" of backspacing. (if i can find one). back to google i go.
  13. May 30, 2011 at 10:14 AM
    KPT
    09 Prerunner
    Why do you want 5.5" backspacing again?
    4.5 gives you more options down the road.
  14. May 30, 2011 at 10:17 AM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
  15. May 30, 2011 at 10:20 AM
    KPT
    09 Prerunner
  16. May 30, 2011 at 5:31 PM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    ok. so my stock wheels are +38mm with 5.5 backspacing. so if i go for 4.5 backspacing and 12mm wheel will i have any concern with rubbing/trimming ?
  17. May 30, 2011 at 5:33 PM
    KPT
    09 Prerunner
    They are not. They are +38mm offset with 5.5" backspacing, as I already noted.
    However, the 4.5" backspacing wheels will still work, in fact they will give you more options for running wider tires because they moved the wheel away from the uca.
  18. May 30, 2011 at 5:38 PM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    sorry about that KPT, i misread your "incorrect" for correct. guess thats what i get for not having my glasses on.
  19. May 30, 2011 at 5:40 PM
    KPT
    09 Prerunner
    No problem. But I would look for 4.5" backspaces wheels if I were you, rather than trying to match something to stock.
  20. May 30, 2011 at 7:23 PM
    FuzzHead
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    any advantage of stepping up to a 16x8 vs the 16x7 ? (they both have 4.5" of backspacing)
    no plans to drive offroad, but i do drive thru some really deep snow if i get out before the plows in the morning. so far the plan is to run 265/75 but i may look for a skinnier tire for to help drive thru snow.
