Whiteclouds Build and BS Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Whitecloud, Aug 9, 2011.
  1. Jul 1, 2015 at 12:37 PM
    #361
    Whitecloud
    Whitecloud [OP] Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
  2. Jul 1, 2015 at 12:41 PM
    #362
    Adamw1988
    Adamw1988 Well-Known Member
    Adam
    West Tennessee
    2015 Trd sport
    Nice Truck!
  3. Jul 1, 2015 at 12:42 PM
    #363
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    ok so to be clear the red is always on an the upper part lights up when the switch is in the on position?
  4. Jul 1, 2015 at 12:48 PM
    #364
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Thanks.
    @StOrMyThEtAcO Yep. Lower part is always on, when you hit the switch the upper part lights up red as well. They have a bunch of different options on colors. If you want the upper part lit up all the time and the lower when pressed then you need the "SPST Upper LED Independent" one.
  5. Jul 1, 2015 at 12:49 PM
    #365
    StOrMyThEtAcO
    Cody
    CO
    All of them
    awesome man thanks for the help!
  6. Jul 1, 2015 at 12:51 PM
    #366
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Of course. Anytime.
  7. Jul 2, 2015 at 10:41 PM
    #367
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Truck is coming along nicely cloud
  8. Jul 3, 2015 at 8:57 PM
    #368
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Thanks buddy.
  9. Sep 6, 2015 at 1:53 PM
    #369
    Canadian Taco 705
    Canadian Taco 705 Well-Known Member
    Windsor Ontario Canada
    2010 Black 2.7L 2WD Debadged
    Interior: Hardwire GPS Hardwire USB x2 Extra Cig Lighter Mag Light Mod x2 Exterior: Debadged TRD hood Bull Bar Halo Headlights 6000K Lumens HID 50% Windshield Tint 5% Window Tint
    just gonna post this here so i can refer back to it for your sliders nice truck bud!
    Whitecloud[OP] likes this.
  10. Sep 6, 2015 at 11:54 PM
    #370
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Thanks.
  11. Sep 18, 2015 at 1:02 PM
    #371
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    So @seattlesig also had some questions about my wiring. I'll try to briefly answer some questions here but I'm working on writing up a more detailed post in my build thread since a few of you guys have asked for a write up and how to. I wouldn't mind doing more harnesses for those that want them just realize that they will take some time to do.
    So with my wiring I grabbed a bunch of OTRATTW switches, the Red/Red with the Lower LED Independent. A huge chunk of wiring, an @Iggy. switch panel and a few other little do-dads.
    In regards to the wiring, this was the diagram that I used......
    I wired all the ground, hot, and ignition, in series so that I didn't have to run double the wiring......like so...
    The hot (red) wire, #2 on the diagram, went to the positive side of the battery to power the switch panel. Ground (green), #7 and #8 on the diagram, to the ground bus bar that is in the engine bay and hooked to the batteries. The white (ignition), #6 on the diagram, is currently wired to the positive side of things and is currently always illuminated and all the switch panels will be wired into another ignition based fuse in the near future. The wire to engage the accessory, #3 on the diagram, is then also measured and connected to the switch to be run with the rest of the bundle.
    All the wiring is then concentrically wrapped, covered in shrink wrap, and run through the firewall. I pulled the OEM firewall boot away from the firewall, sprayed everything down with some electrical lube and run all of the harnesses that I built through the firewall.
    dakotasyota likes this.
  12. Sep 22, 2015 at 7:05 AM
    #372
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    So I was going through your build thread again, can you tell me more about this set up? Whats the AMG 175A next to the 100amp breaker do? I'm just about to put mine together and I'm going off of what others have done, but I have not see that before.
  13. Sep 22, 2015 at 10:49 PM
    #373
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    I just did it as a back up to the breaker. Just in the off chance that the breaker fails.
  14. Sep 23, 2015 at 5:11 AM
    #374
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    With all those wires no one wants the truck burning down. I fear this sometimes too. But my truck will be the LAST truck I wire. With the invention of the Bluetooth system now no more wires to run to the cab. :)
  15. Sep 23, 2015 at 5:31 AM
    #375
    ERMB
    2002 Land Cruiser
    Por que? Are you talking about the trail toys buss w/remote?
  16. Sep 23, 2015 at 12:14 PM
    #376
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Exactly. Hence the redundancies. But now there is issues with the IBS system and the Aux battery not charging and showing on the IBS display.
  17. Sep 24, 2015 at 7:28 PM
    #377
    Gramps
    Gramps
    07 TRD DC 4x4
    That's one version but there is another out there Switch Pros that has a smart phone app that you can Bluetooth your phone too.
    ERMB[QUOTED] likes this.
  18. Sep 25, 2015 at 9:42 AM
    #378
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    I've been contemplating the IBS system when I eventually do a dual battery setup. What's going on with yours? Can you offer any feedback? Pros and cons?
  19. Sep 25, 2015 at 1:07 PM
    #379
    ERMB
    2002 Land Cruiser
    Are you currently using this or is this a future upgrade?
  20. Sep 25, 2015 at 1:16 PM
    #380
    Gramps
    Gramps
    07 TRD DC 4x4
    No point in going backwards with my truck. I have wires running everywhere. But I will get this for my 4 runner.
