Whiteline LCA bushings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD FTW, Nov 26, 2019.
  1. Nov 26, 2019 at 2:01 PM
    DrFunker
    DrFunker Well-Known Member
    I do also use a BJ press kit (sleeves). The one that the auto shop loans out.
    I have since bought my own so I don't need to borrow it.
    Much like this:
    But it looks like a bearing press kit may work as well.
  2. Nov 26, 2019 at 2:07 PM
    DrFunker
    I would also suggest swapping out the washers from the ones WL provides to something harder. See Crom's thread about what may happen to them.
    I did find harder ones at Fastenal for one of the sizes, I am planning to get there this week to see if they have the other size washers as well.
  3. Nov 26, 2019 at 3:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s a good idea, mine are bowed a bit.
    DrFunker[QUOTED] likes this.
  4. Nov 26, 2019 at 4:04 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    He's doing mine currently and he knows his shit
  5. Nov 26, 2019 at 4:12 PM
    DrFunker
    o_O Who?
  6. Nov 26, 2019 at 4:15 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You
  7. Nov 26, 2019 at 4:16 PM
    DrFunker
    :oops: aww shucks.
    Thanks Rick.
    I credit all the people here for what I know.
  8. Nov 26, 2019 at 4:17 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes but this is the second set you have done for me
  9. Nov 26, 2019 at 4:18 PM
    DrFunker
    Your first set was easy. :D
  10. Nov 26, 2019 at 4:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Huh the brand new set of OEM LCA's I gave you should be easier no?
  11. Nov 26, 2019 at 4:21 PM
    DrFunker
    The large bushings are in there good. Haven't applied the heat though. That is next. :devil:
    May get to them this week.
    fatfurious2 likes this.
  12. Nov 26, 2019 at 4:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    No rush not going on until Spring Chris
  13. Nov 26, 2019 at 4:29 PM
    DrFunker
    Cool.
  14. Nov 26, 2019 at 7:49 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Do share the sizes if you get a chance and way ahead of you. Bought my own BJ press kit. I am ready to tackle this. Thanks for all the helpful tips.
  15. Nov 27, 2019 at 2:10 AM
    #35
    DrFunker
    I just took the washer into Fastenal with me and we got it matched up.
    I am planning on heading there today to see if they have the other ones too.
    outxider[QUOTED] likes this.
  16. Nov 27, 2019 at 4:18 AM
    #36
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yeah Buddy
  17. Nov 27, 2019 at 6:42 AM
    #37
    DrFunker
    Went to my local Fastenal this morning.
    The guy said that the larger washer is not available any harder than the Whiteline one, but the other is (which I bought a while ago).
    He asked if there was enough space to double the larger washer with one of the harder washers. That may work depending on how much extra space is there.
  18. Nov 27, 2019 at 7:16 AM
    #38
    4WD FTW
    4WD FTW [OP] Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    That's about the same method I was using. Except the cup I had seemed to be a perfect fit over the sleeve. I think the biggest issue was the inability to even get it started in the arm at the correct angle. I read many posts where they claim the moog bushings go in a little way in fairly easy which would be a tremendous help. I'm sure Whiteline is a good company and the bushings are good quality but my goal here is to stir up some discussion and maybe prevent someone from making the mistake I did. I definitely put my icons to the test so we'll see how tough these moog arms are soon enough.
    If it matters any, I did measure the parts with a digital caliper. I forget the exact numbers but the bushings were .03-.05 mm bigger than the arm. And the arm was not a perfect circle, it was slightly oval by .03 mm but it was the same from front to back on both cups so I assumed that was normal. I'm not sure what would cause both of them to turn that shape if it wasn't.
    A note for anyone considering doing this with a balljoint press, you quickly run out of room to use all the correct sleeves and cups unless you have a very large one. Some kind of hydraulic press or jack is a must. The only good news about the balljoint press is I got one hell of a workout.
  19. Nov 27, 2019 at 9:23 AM
    #39
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    TacoPandaTRD and DrFunker like this.
  20. Nov 27, 2019 at 9:33 AM
    #40
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The small busing 1.75" and the large bushing 2.08"
