Whiter headlight bulbs?
Discussion in 'Lighting' started by KevC, Oct 28, 2016.
  1. Nov 17, 2016 at 2:39 PM
    #41
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Yeah! I'll give it a try and see how much it last in my case.. I don't turn on my headlights until I need them.. when its sunset I like to turn on my amber lights and the fog lights (in miami there's NO fog) but I like to use them and like how the truck looks..
    jonnyozero3[QUOTED] likes this.
  2. Nov 17, 2016 at 2:53 PM
    #42
    Otis1382
    Otis1382 Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    I got it. I didn't have a dremel or anything to trim that plastic tab inside the housing. popped out the trusty pocket knife, job done. I got the hella bulbs. so far I'm not very impressed but its still a little light out. ill wait until night to pass judgment.
  3. Nov 17, 2016 at 3:11 PM
    #43
    Claudiomartinof
    Hahaha this thing about if hid, led, h9 mod are brighter or not is totally personal... in my case I noticed a better output but you say that is not that much.. hahaha let us know what do you think of it when you test it at night..
    I did the mod about 2 weeks ago and I haven't tried them on a very dark area.. my commute is 99% highway.. and on weekends I use my wife's Prius c that have more mileage than my truck and is a champ on gas consumption so I don't know when I'm going to be able to enjoy the "brightness" of my new bulbs haha..
  4. Nov 17, 2016 at 3:24 PM
    #44
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    I wanna see some night shots of the H11 to H9 mod!
  5. Nov 17, 2016 at 4:30 PM
    #45
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I have like 5 sets of h11 and h9 bulbs
  6. Nov 17, 2016 at 4:35 PM
    #46
    avitaco
    A
    2017 DCSB 4x4
    Also, the Manufacturer gave a 2000 hrs of use on my h9. so maybe the new ones are getting more use
  7. Nov 17, 2016 at 4:38 PM
    #47
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Oh wow, nice. Maybe I screwed up my data...
  8. Nov 17, 2016 at 4:43 PM
    #48
    Claudiomartinof
    Which brand do u have??
  9. Nov 17, 2016 at 4:47 PM
    #49
    avitaco
    A
    2017 DCSB 4x4
  10. Nov 17, 2016 at 5:00 PM
    #50
    Claudiomartinof
  11. Nov 17, 2016 at 5:18 PM
    #51
    avitaco
    A
    2017 DCSB 4x4
    I doubt your hellas will and neither will these bulbs. I wouldnt be surprised if on or more burned out but I have spares and they are bright and seem to work well so I am happy with the purchase. I will prob upgrade to different bulbs when one of these burns out.
  12. Nov 23, 2016 at 2:52 PM
    #52
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    avitaco and Claudiomartinof like this.
  13. Jan 6, 2017 at 7:42 AM
    #53
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    So you're saying that the only part of the bulb you modified was the actual plug? and not the flanges near the base of the bulb?
  14. Jan 6, 2017 at 8:23 AM
    #54
    J0mes
    J0mes Active Member
    James
    16' TRD Off Road
    This looks great! Did you have to re aim the lights at all?
    I am pretty much sold on this and going to order mine now, will post my results later. I'll try to do a H11/H9 Night comparison to see how far the and consistent the light is thrown/brightness contrast, unless someone else wants to post it up here. :infantry:
  15. Jan 6, 2017 at 8:52 AM
    #55
    Pistol Pete
    Eric
    Oklahoma
    I did not have to re aim, they were at the same position on the wall.
  16. Jan 6, 2017 at 8:57 AM
    #56
    DavidMietzner
    DavidMietzner Well-Known Member
    David
  17. Jan 6, 2017 at 9:03 AM
    #57
    J0mes
    J0mes Active Member
    James
    16' TRD Off Road
    True, just asking cause the spread is like 3x bigger than the H11 bulb didn't know if its sitting to high for the bulb. I like them and all, would just like to be aware if someone is catching a front seat to the light show. Thanks man.
  18. Jan 6, 2017 at 9:08 AM
    #58
    Pistol Pete
    Eric
    Oklahoma
    I have yet to be flashed from oncoming traffic, and when behind cars the cutoff is just below the top of their trunk. Stock height btw.
  19. Jan 6, 2017 at 7:44 PM
    #59
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    H9s are not designed to control the beam pattern the way an H11 is, hence the high beam H9 bulbs do not have glare shield end caps like the low beam H11 as they are not intended for low beam use.
    In a halogen headlight assembly the light is controlled by not allowing it to escape directly out the front of the assembly without first reflecting off the back of the assembly to give precision control of the beam. On a high beam, it doesn't matter if light escapes directly out the front of the assembly uncontrolled, because your high beams are on so no-one must be in-front of you. Hence on an H9 high beam bulb there is no glare shield. On an H11 bulb there is a glare shield. Hence the connector being different so you don't put an H9 into an H11 housing. Yes you can modify it to make it fit anyway.
    This is the correct way to do it if you want to get more output out of your H11 halogen bulbs, providing a measured 2x improvement over stock:
    https://www.tacomaworld.com/threads/the-ultimate-foglight-upgrade-not-led-or-hid.435419/
    And if you really wanted whiter bulbs (understanding you are sacrificing performance and life over the non-coated bulbs) these 80w while H11s would do the trick:
    http://www.rallylights.com/bulb-h11-12v-optilux-extreme-xenon-blue-pair.html
  20. Jan 6, 2017 at 7:46 PM
    #60
    dmccurdy7
    dmccurdy7 Lurker
    Doug
    Caldwell, ID
    2010 6MT ACLB TRD Off Road
