Who’s running 4.88 on 265/70/17 tires?
Discussion in '4 Cylinder' started by Sep1911, Jan 6, 2023.
  1. Jan 6, 2023 at 12:56 PM
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    Just wondering how you like the setup. I’ve been running 4.88s to spin my 285/75/16s for some time now. I’m at a point where I’m tired of the hassles of running heavy tires/wheels and would like to switch to something lighter. I know the engine will rev a little higher on the highway but I don’t think that’s a big deal personally
  2. Jan 6, 2023 at 1:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    2900 rpm at 70 sounds pretty good for a 4 cyl. It's not going to be much different from what you have now though. The 33's measure about 1.2" larger than the tires you're considering switching to. The difference in rpm at 70 mph is really only about 110 higher.
    Going with an SL tire when you downsize will help. Pretty sure all the 285/75s are LT.
  3. Jan 7, 2023 at 11:46 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Man I would love your gearing with my 255/75/17s 4-ply DuraTracs!
    Even 255/80/R17 if you want a 34”
  4. Jan 7, 2023 at 12:54 PM
    Sep1911
    2016 Taco
    On my 285/75/16s with the 1st ratio on the manual it’s a dream. Truck will drive it self on obstacles.
    I’m looking to shed some serious weight. The rate I go through wheel bearings and other suspension components is pretty ridiculous for the age and mileage of the truck. I’m looking at the scs 5 wheels compared to the rock crushers I have. It’ll be a HUGE reduction in weight. But I’m thinking this could be a good time to make the switch to 17s. There are some interesting sizes available in 17s. On the other hand the more “fun” sizes with some aggressive tread land you in the D/E load tires which end up being almost double the weight of factory stuff. I’m really trying to find a good compromise here but I am also leaning towards pizza cutters. I was seriously considering pizza cutters previously but 255/85/16 is practically the only size and options were limited. It seems as of now they are more abundant
  5. Jan 7, 2023 at 8:20 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    2900rmp at 70mph? im on 265 ko2's C load rating and im getting a little above 2000rpm at 70mph. 2018 2.7
  6. Jan 7, 2023 at 8:46 PM
    BLtheP
    Plano, TX
    Because you have the automatic.
  7. Jan 7, 2023 at 9:41 PM
    mushroom_man7
    ooh okay thanks
  8. Jan 8, 2023 at 7:48 PM
    Greenbean
    Zack
    Western NC
    I’d still go 17, my 17s are 32” pizza cutters, 4-ply.
    The mold it seems is shared with the 34” pizza cutters also,
    Lots of c or d ply in 17” vs 16…
    I love 16” 255/80s but the old Coopers were the only d tires and they have been discontinued for a couple years now.
